Go to Post If this photo doesn't tell us why a photographer is important to a team, I don't know what will. - JaneYoung [more]
Unread 24-07-2016, 21:15
Harrison.Smith Harrison.Smith is offline
Business, CAD, Mechanical
Harrison.Smith is a name known to allHarrison.Smith is a name known to allHarrison.Smith is a name known to allHarrison.Smith is a name known to allHarrison.Smith is a name known to allHarrison.Smith is a name known to all
Re: pic: Experimental VP drive gearbox
Originally Posted by mman1506 View Post
Would you mind sharing some pictures/details of your gearbox especially the VP input? It would greatly appreciated.
The larger pulley is on a keyed 8mm shaft that is going through a bearing, then we have the input block bearing on an input coupler. Then we have a modified input coupler (removed the flange). This is what drives the sun gear. The VP is set up: dead stage, 7:1, Encoder. Hope this helps!
https://drive.google.com/open?id=0B8...1Q3Z01aV2tMTlk
https://drive.google.com/open?id=0B8...nZlNGU4YzNpSDA
