Go to Post It's easy to get so caught up in the intensity of build that we forget we need some down time to recharge and get a fresh head. Taking a day off will only happen if you make it a priority as important as any other team meeting. Long hours do not equate to productive hours. - Greg Hainsworth [more]
Unread 27-07-2016, 18:03
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
Re: pic: 1058 Low Expectations Intake Render
We built a very similar intake this past year but powered the rollers off of the upper feed system (to reduce motors and save weight), and direct-drove the angle-adjustment motor by internally coupling it to an extension inside the roller.
In retrospect it was way over-complicated and this looks like it would have been a much simpler (and easier to maintain) way to go.
Unread 28-07-2016, 16:38
messer5740's Avatar
Happy Birthday! messer5740 messer5740 is offline
FRC #5740 (Trojanators)
Rookie Year: 2015
messer5740 is an unknown quantity at this point
Where can I buy the pulleys that are next to the intake wheels and the belt/tubing thing that rounds the pulleys?
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: 8th seed alliance captain at Greater Pittsburgh Regional and 6th seed alliance captain at the Buckeye Regional
Thanks to all our alliance members!
Unread 28-07-2016, 16:49
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
That tubing is called polycord (or Urethane Belting if you actually want to find it). McMaster. I am guessing that they 3d printed their pulleys.
Disclaimer: All references to rules and legality are from current or past seasons and it should not be assumed that any rule will remain the same in future seasons.
Unread 28-07-2016, 17:14
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
We made the pulleys ourselves using 2.25" acetal that we got pretty cheap from a company in our town. We have access to three lathes and eager students so it wasn't too time consuming. We cut them to length, turned down a groove in the center to fit the cord, bored them to 1/2", and then hex broached them.
Looking back I probably would have just done what 188 Blizzard did which was use the Colson wheels as their pulleys. https://www.youtube.com/watch?v=UOMRgVIzI0M
That's the stuff. We used the 1/4" round solid core tubing.
1058 PVC Pirates 2016 - xxxx
