Re: paper: 4 CIM versus 6 CIM theoretical calculations
A great overview of the continued advantages of 6 CIMs over 4 - provided that you watch the total current!
Assuming 200A for the drive train is simplistic, but a good way to compare apples to apples. No matter what the battery state is, you will have a certain limited current you can draw from it before beginning the brownout process. The first (and so far only) technical error was the sentence that spans from the first page to the second. It should read something like: Quote:
Another thing to consider if planning a drive train with current limiting is whether using some other motor will be more effective to your strategy than CIMs. A cursory review of the mini-CIM finds it to be inferior in most cases, as it has lower efficiency than the CIM at any given current draw, but there are probably cases where it is the proper choice, due to weight considerations or specific needs. If you're going to do proper current/speed and/or thermal monitoring, you may want to add the 775 pro or other low thermal mass motor to your considerations. |
In practice, my guess is that you can draw way more current than 200 amps. Just based off of my team's 2016 drivetrain, which was 4 CIM with no voltage ramping, we experienced no brownouts even going from full forwards throttle to full backwards throttle. If we assume that our robot was traction limited below 40% of our max speed (a conservative assumption), we were drawing over 300 amps max.
Another cool aspect to current limiting is changing the limits in real-time based on each subsystem's need. For example, in a 4 CIM "hard right" turn -- 0% power on the right drive side, 100% on the left -- you may only be drawing 50% of what the battery is able to provide. If you have 1.5 or 2 times the power and current limit, you can double the current limit on the left side so that you fully utilize the battery. This same idea can be used to change the current limits to better follow a motion profile or prioritize superstructure motions. One last important item to keep in mind is the main breaker. A high power drivetrain with a current limit pulls the maximum current for more time than an equivalent lower power drivetrain. Because the main breaker is heat triggered, it is sensitive to prolonged periods over the 120 amp breaker limit, and therefore high power drivetrains are more likely to blackout than lower power drivetrains. Given that the talon SRX now supports current PID, a lot of doors have been opened for teams to find performance improvements with current limiting. Last edited by MichaelBick : 31-07-2016 at 01:33. |
Towards the end of the appendix A is a sentence that starts with "One final thought: ..." Is that supposed to carry on to the last paragraph somehow or is it just incomplete?
Great paper, this was a good introduction to 6 CIM drives for me in terms of the math. The idea of current limiting sounds pretty cool and is definitely something that could be implemented with the Talon SRXs to tune performance and prevent brownouts. |
1. Mechanical power output is not everything. You need to have useful power; proper gearing. However, yes, having more mechanical power output won't hurt.
2. How do you magically draw a hard limit of 200 (or whatever) amps without effecting voltage input to the motors? Though you may be "limited" to 200 amps, when you're drawing this much current, voltage dips due to both surface depletion (?) and voltage drop in the loads to the motors. This shouldn't be ignored. When you drop away from the 12V, the motor curve you use up there is no longer valid. Look into using kV and kT values to model things and take this voltage drop into account. |
I took a decently quick read and had a few questions.
1. I may be misunderstanding what you are stating here: Quote:
2. Would limiting the current draw of a motor be similar to limiting voltage? I.e. would limiting max current have a similar effect to limiting a CIM's output to .5 (In terms of limiting the speed at which the CIM will approach maximum acceleration?) 3. Why not simply control the Max RPM of the CIM in code rather than using a current PID? *I suspect that part of this has been our somewhat low final RPMS from our gearbox reductions. These have both resulted in very short acceleration periods. Thanks in advance for the answers! |
If you only control velocity, you will still draw high amounts of current at stall. For example, a 4 CIM drive will draw 524 amps at stall, and 1048 amps going from full forward to full reverse. This is what causes brownouts. |
Yes, you can draw more than 220A for short durations. This does not change the primary conclusion of the original paper that 3 CIMs operated properly can provide greater mechanical power drawing from a given battery and condition. This is because the only conditions in which three motors run less efficiently than two is on the fast side of the peak of the efficiency curve, when operating near the free speed limit. In this domain, brownouts are not usually of concern. I would not use this paper as the last word in tuning a current limiting system, but I do consider it a valid argument for using a 6 CIM drive train over a 4 CIM drive train when the team's game strategy involves pushing battles or other high-current operation. Alternately, 6 CIMs would allow you to gear the robot faster for a given application, preserving good startup acceleration while increasing top speed, or leave gearing alone, preserving top speed while increasing startup acceleration (in torque-limited drives). This would not be nearly as much of a difference as a shifting gearbox, but it would be simpler and less expensive. |
I'm a little busy to check this but I'd like to know how these calculations line up with the results in this paper:
https://www.chiefdelphi.com/forums/s...d.php?t=131790 |
Whoops, I didn't notice that error. Rest assured that the calculations were done the correct way (and not the way stated in the paper!) I'll change that and re-upload soon. I was considering a 10 775pro drivetrain just before I left for the mountains on Friday, and will do some calcs for those too soon. Quote:
The main reason to use 200 amps was to allow me to do just a comparison between 4 CIM and 6 CIM given other constant variables. I'm not too worried about the main breaker. It was a problem in 2014, but main breaker blows these days are extremely rare IMO, just because brownouts happen well before blows. Early in the season we browned out many times in practice, but never faced a breaker blow. I forgot that the SRX can do that! That makes this way easier. In that case using the function in my paper isn't really necessary because you can just PID the current directly. That being said, coming up with a separate algorithm that takes into account battery voltage drop and max current vs. time would probably be better. Quote:
"One final thought: Because a 6 CIM drive hits 200 amps at almost 4,000 rpm, where as a 4 CIM drive hits 200 amps at 3,300 rpm, the 6 CIM drive will be able to utilize all 200 amps for acceleration closer to the free speed of the drivetrain. A 4 CIM drive might only be able to get 200 amps worth of torque up to 12fps in a 16fps free speed drivetrain, whereas the 6 CIM drive can get up to 14fps before dropping under 200 amps current draw." That makes the gap between 4 CIM and 6 CIM larger. Thank you! Quote:
My understanding of the motor curves was that the current and RPM decrease proportionally to the proportion of 12v that you are running at. I.E. if you run a CIM at 6v, it will have a free speed of 2,640rpm and a stall current of 66 amps. What do you mean by "voltage drop in the loads to the motors"? Like losses in the wires? I was supposed to make a new equation that took into account voltage drop and used kT and kV to make a better comparison while I was in the mountains, but I didn't get around to it then. If you have any current draw vs. brownout graphs or anything like that I would appreciate it. Quote:
2. Michael got it. 3. Current PID (or maximizing current draw without browning out) will let you get the most out of your drivetrain in terms of acceleration and safety. This is important if you want to run a drivetrain at high speeds and still not suffer from decreased acceleration and brownouts. Quote:
The lead acid batteries used by FIRST are about 17 Amp-Hours. They are certainly capable of discharging in excess of 300 amps for a few seconds.
The roboRIO brown out control is based on a voltage threshold of 6.3 Volts. And thus has 5.7 volts of margin with a fully charged battery. You could reasonably model this situation as a 12 V voltage source with 0.05 Ohms of resistance to the power distribution board; and 0.3 Ohms of resistance through each of motor controls (Talon SRX) and wiring. A CIM motor has a stated Stall current of 131 amps at 12 volts. For the instantaneous stall current, you could model the equivalent resistance as R=V/I = 12/131=0.09 Ohms So each CIM motor circuit would have a Series Resistance of 0.09+0.3=0.39 Ohms. Parallel resistances are totaled as 1/Rtotal = 1/R1 + 1/R2 +…+ 1/Rn Four CIMs have a combined parallel resistance of 0.0975 Ohms. Six CIMS have a combined parallel resistance of 0.065 Ohms Four CIMS The Four CIM total Resistance is 0.05+0.0975=0.1475 Ohms Current: I=V/R=12V/0.1475=81.4 Amps The voltage drop at the RoboRio is V=I*R=0.05*81.4= 4.07 Volts The roboRIO has 1.63 Volts of margin for a brown out. 12-6.3-4.07=1.63 Six CIMS The Six CIM total Resistance is 0.05+0.065=0.0115 Ohms Current: I=V/R=12V/0.115=104.3 Amps The voltage drop at the RoboRio is V=I*R=0.05*104.3= 5.21 Volts The roboRIO has 0.49 Volts of margin for a brown out. 12-6.3-5.21=0.49 What happens later in the match when the Battery voltage has drooped down to 10.5 Volts? We will leave the CIM resistance unchanged, even though they are now quite hot. Same with the wiring resistances. Four CIMS Current: I=V/R=10.5V/0.1475=71.2 Amps The voltage drop at the RoboRio is V=I*R=0.05*71.2= 3.5 Volts The roboRIO has 0.7 Volts of margin for a brown out. 10.5-6.3-3.5=0.7 Six CIMS Current: I=V/R=10.5V/0.115=91.3 Amps The voltage drop at the RoboRio is V=I*R=0.05*91.3= 4.57 Volts The roboRIO is -0.37 Volts below the brownout voltage. 10.5-6.3-4.57=-0.37 Summary: Standard four CIM Drives consistently maintain a 1 Volt higher brown out margin than six CIM drives. While a Six total CIM Drive can accelerate 150% faster than a Four CIM drive, it does come at considerable more risk of brownout event. Each team will have to balance drivetrain performance vs. robot reliability for the entire match. Last edited by InFlight : 02-12-2016 at 12:18. |
#12
I'm not sure if your model is perfect however. Are you assuming a stalled CIM? A CIM's resistance becomes less important as it speeds up, although I assume that you are doing the math for starting from a standstill.A possible solution to this could be just basic speed ramping. |
#13
Every forum needs a lurking electrical engineer.
This was just at the initial state of powering the motors, with no initial velocity. My resistance values for the wiring resistances are just reasonable guesses. The actual amperage values could be larger or smaller, but the trends with the brownout margins would be consistent. The other note is the motors windings only get a fraction of the full stall current; because the battery and wiring system resistance can't deliver that much current. |
#14
The Mini-CIMs is really the equivalent to 1/2 a CIM in terms of torque and current. If a team wanted a competive advantage of running a three motor gearbox per side; the combination of two CIMs and one Mini CIM would be a better choice. It would provide 125% the performance of a 2 CIM drive, with more brownout margin than a 3 CIM drive. |
