Go to Post Anything released in a game hint is subject to enough misinterpretation and "nah, they'll never do that" to deflect any possibility of something being actionable. - EricH [more]
Unread 31-07-2016, 11:12
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Re: paper: 4 CIM versus 6 CIM theoretical calculations
I took a decently quick read and had a few questions.
1. I may be misunderstanding what you are stating here:
4CIM 200/524 = 38%
Are you saying that a 4 CIM drive should be limited to 38% per a motor in order to keep your robot below 200amps of power usage? If so, I think that the 200 Amp number is actually pretty far from the limit of the power system of a modern FRC robot; we have run 4 CIM drives without any voltage ramping and never had any issues with brownouts.*
2. Would limiting the current draw of a motor be similar to limiting voltage? I.e. would limiting max current have a similar effect to limiting a CIM's output to .5 (In terms of limiting the speed at which the CIM will approach maximum acceleration?)
3. Why not simply control the Max RPM of the CIM in code rather than using a current PID?
*I suspect that part of this has been our somewhat low final RPMS from our gearbox reductions. These have both resulted in very short acceleration periods.
Thanks in advance for the answers!
Unread 31-07-2016, 12:21
FRC #1836 (MilkenKnights)
He is saying that @ 0 RPMs you need to provide 38% of full voltage to draw 200 amps total. At higher RPMs you will need to provide more voltage to draw the same 200 amps. Similarly you need to provide even less voltage if the robot is traveling backwards initially.
Halving voltage halves no-load speed, halves torque, and results in 25% mechanical power. On the other hand, limiting current limits torque and thereby limits acceleration. This by itself is very helpful, even without the power increase that is mentioned in the paper, because it causes robots to be much more stable.
If you only control velocity, you will still draw high amounts of current at stall. For example, a 4 CIM drive will draw 524 amps at stall, and 1048 amps going from full forward to full reverse. This is what causes brownouts.
