Go to Post I will follow FIRST's guidelines, as long as they conform with those of the English language. - artdutra04 [more]
Unread 02-08-2016, 07:41
SerpentEagle's Avatar
SerpentEagle SerpentEagle is offline
AKA: Shashank Rajesh
FRC #3641 (The Flying Toasters)
Rookie Year: 2015
SerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to behold
pic: Another Swerve
Unread 02-08-2016, 07:43
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Re: pic: Another Swerve
Originally Posted by SerpentEagle View Post
Looks a bit hollow... You'll want a belly pan or the like to stiffen the frame (otherwise you'll have a lot of flex).
Unread 02-08-2016, 08:35
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Is there a speed encoder on there? I see one for turning... which i think is 1:1.
Source files? This looks cool.
"La mejor salsa del mundo es la hambre" - Miguel de Cervantes
"The future is unwritten" - Joe Strummer
"Simplify, then add lightness" - Colin Chapman
Unread 02-08-2016, 09:27
cad321 cad321 is offline
AKA: Brian Wagg
FRC #2386 (Trojans)
That lightening pattern on the gearboxes look a little too pocketed to me. I'd probably add a little more meat to them there. Aside from that I like it. And as ratdude said, you'll want a belly pan for added rigidity.
Unread 02-08-2016, 11:16
The gearbox pattern might be a little too much, but given the layout it's probably not fatal. The main thing I would do with that is make the webs going to the big pivot larger (5/16" or even 3/8" wide).
The chassis looks fine to my eyes. The pattern is similar to 971's patterns this year, and didn't decrease stiffness noticeable last time I checked in simulation. Given the large square shape, however, adding a wooden bellypan would be to your advantage.
Unread 02-08-2016, 12:28
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
I would be concerned about having the CIM there so near to the ground. In a game with some field obstacles, you could probably rearrange a couple things and move the CIM to the top plate (through the bottom plate). There are several disadvantages (higher CG, cantilevered gears, etc.), but could be necessary.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 02-08-2016, 12:32
Cothron Theiss's Avatar
What is the reduction and fps on that? It appears to be quite zippy, given that I can only see two reductions, neither of which are very extreme.
Unread 02-08-2016, 13:13
Rookie Year: 2015
Yeah, I plan to add one in the end.
Yeah, theres a versa planetary encoder for the turning. Haven't added the drive encoders. I was only a couple hours into this.
Ill upload this to grabcad later on. Thanks.
Agreed
This is designed to be an offseason project, so this is assuming a flat field, like in 2014.
Its 1:3.333 with a 3.25 OD wheel. Aroud 18 fps according to JVN's calculator. This is designed for an offseason project, so it wont weight more than 45-50 lbs. I might slow it down a bit later on.
