Go to Post A Mentor is.. A person you can talk to anything about and trust them to not throw it back in your face in any way shape or form and who will help you as much as they can to deal with the problems and situations in life... - Elgin Clock [more]
Unread 10-08-2016, 16:56
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
Re: pic: Its twins - prototype drives
Between the bumpers and mechanisms installed this should stiffen up the frame. If I get a chance (it won't be soon) I will post the CAD drawings of the plates. We actually used the Andymark CAD to find the distances. Far as efficiency loss, I am not concerned, its small and our mechanisms are geared correctly with low power use so if we have loss at the match it will be over before it is a problem. We will just recharge the battery a little more. Between the front wheels, center and rear wheels their is a difference of .375 inch. The side plates are 3/16 thick. We do plan on cutting the bolts shorter or go with aluminum with C clips but we have had problems with the C clips coming off. The chain wrap is a problem, but we do not plan on using the center 4 inch wheels on future designs. We wanted to put double sprockets on that wheel but we only have 2 inches between the side plates and the chains barely clear now. One unit weighs 20 pounds.
