Go to Post Every year, everyone reads too much into the hints given by Dave. - EricH [more]
Unread 20-08-2016, 10:03
AGPapa's Avatar
AGPapa AGPapa is offline
AKA: Antonio Papa
FRC #5895
AGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond repute
pic: 2016 Championship Alliance Selection Rates by Qualification Type
Unread 20-08-2016, 10:05
ATannahill ATannahill is offline
AKA: Alex Tannahill
ATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond repute
Re: pic: 2016 Championship Alliance Selection Rates by Qualification Type
Originally Posted by AGPapa View Post
Do these numbers include the alliance captain at the Championship or not? The first sentence implies that they are excluded.
- Arizona North
Unread 20-08-2016, 11:51
AGPapa's Avatar
AKA: Antonio Papa
FRC #5895
They include everyone who made it to the playoff rounds at the championship. The captain, 1st pick, 2nd pick and sub (even if the sub wasn't used).
Team 2590 Student [2011-2014]
Team 5684 Mentor [2015]
Team 5895 Mentor [2016-]
Unread 21-08-2016, 02:47
Brian Maher's Avatar
Brian Maher Brian Maher is online now
Questionable Decisionmakers
FRC #2791 (Shaker Robotics), FRC #1257 (Parallel Universe)
Brian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond repute
These are some really neat stats, thank you for sharing!
Question: did you pull your data from the FMS API or TBA, and how did you differentiate between waitlist and points teams in districts? As someone who uses the TBA API, I've found this to be problematic.
If it's not too much trouble, I'd love to see the breakdown by:
  • level of playoffs reached
  • captain / first / second / third picks
I think it could be interesting to compare with overall alliance selection rates.
2016-present, Mentor, FRC 2791 - Shaker Robotics
2016: Tech Valley SF (5236, 2791, 3624) and Quality Award, Finger Lakes SF (5254, 2791, 2383), Battlecry@WPI Winner (195, 2791, 501), Robot Rumble Winner (2791, 195, 6463)
2016-present, Mentor, FRC 1257 - Parallel Universe
2016: Mount Olive Winner (1257, 5624, 1676), Bridgewater-Raritan Finalist (1257, 25, 3340, 555) and Gracious Professionalism Award, MAR CMP Winner (225, 341, 1257), Archimedes SF (4003, 4564, 5842, 1257), IRI Invite
2012-2015, Student, FRC 1257 - Parallel Universe
2015: Mount Olive QF (1257, 1811, 1923) and Industrial Safety Award, North Brunswick Finalist (11, 193, 1257) and Team Spirit and Industrial Safety Awards
2014: Clifton Winner (1626, 869, 1257), MAR CMP QF (1257, 293, 303)
2013: TCNJ Industrial Safety Award
2012: Mount Olive QF (204, 303, 1257)
Unread 21-08-2016, 11:48
AGPapa's Avatar
AKA: Antonio Papa
FRC #5895
Thanks! I found it interesting that the 1st picks did better than the captains.
I took the list of qualified district teams from http://frc-districtrankings.usfirst.org/ and removed all of the teams that had otherwise qualified. Then I took the top X teams (where X is the number of points slots for that district) and called those the district points teams and everybody else was waitlist. There was a pretty clear cut off from when the points spots end. It's a pretty tedious process so I just uploaded the spreadsheet as a whitepaper if you want to use if for something else.
Here's a chart showing where these teams were picked. Some of the group sizes were small and created a noisy graph, so I removed every group that had fewer than 10 teams in it.
Unread 23-08-2016, 09:11
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
...snip...
So, it makes sense if you look at the probability of the two roles. You can end up in the #1 spot as a decent, but not the top performing team. In fact you may be not even a top 10 team at an event.
That first pick is almost always the top or 2nd from the top (when top team is #1).
I know when doing the initial points proposal for FiM, being the "first pick" at an event had the highest correlation with being most competitive and/or most likely to win during a season.
What would be really interesting is to see this chart from 2009 through about 2012. The district Points section would have been extremely high correlation through that time period.
Unread 23-08-2016, 09:37
Another factor to consider is that this year, being an alliance captain required a slightly different skill set than being the consistently highest scoring team at the competition. Being able to guarantee breach and capture inflated the ranks of particular classes of robots, particularly highly mobile low goal scorers, so more of them were top seeds. This is in addition to the normal variance caused by strength of schedule, strategy, reliability, etc.
Unread 23-08-2016, 09:45
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
As seeding has gotten more accurate over the years (largely because of more matches?), 1st picks have gotten less good compared to their captains. This effect you mention is probably the only reason they were better this year.
https://www.chiefdelphi.com/media/papers/2843
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 23-08-2016, 09:48
As long as even some teams are carried, this gap will always exist. Every first pick* by the top seed is one of the top 3 robots at the event; but not every alliance captain is. Maybe that is offset by non-carried captains who declined from a low seed and won the event, I dunno.
*2014 is an exception to all of this because picks were very role based.
