Re: pic: Modular Gearbox
Did you consider using thunder hex stock? Not because it's rounded, but because it has a bore. You could retain the shafts with self-tapping screws and washers (or tap the hole and use elevator bolts) and save a few tenths relative to shaft collars. There may be other pre-bored hex stock out there as well. Churros would work for demonstration purposes, but are not good for transferring the torque you'll need in a drive train, much less an arm. |
*Let me know if I'm not explaining that clearly* |
Updated CAD models are at https://workbench.grabcad.com/workbe...ulyGgP-1FFgvMU The other big problem I can't figure out how to avoid is that the CIM motor needs a trimmed shaft and a spacer (could be CIMcoder) to fit in the thin stage. I was really trying to not need any machining after the blocks are CNC'ed. Does anyone have any ideas how to get around this problem? ![]() ![]() Last edited by Ari423 : 24-08-2016 at 07:52. |
One more thing I want to remind you (and sorry to dominate the posts of this thread!) is that you want to make sure all of the tubing sizes you're using are readily commercially available. For example, .100 wall tubing is very uncommon outside of what Vex sells; most of it is 1/8" wall and 1/16" wall. Also, some of the odder sizes are only available in 6063 tubing, which, albeit weaker and crummier to machine, it is adequate for this application in 1/8" wall if there isn't a 6061 alternative.
Using a final 12:60 chain reduction (max for #35 chain w/ Vex sprockets) after the gearbox, it would take 9 stages. You could then further reduce that by putting the CIMs through a 10:1 VP reduction before it goes into this gearbox (which should be a lot more manageable than a 200:1 VP reduction). You would only need five stages direct driven with a 10:1 VP on the input side. With both the 10:1 VP reduction and the 12:60 chain reduction, you would only need two stages. If you want a 200:1 reduction without a final chain reduction, you can put a CIM through a 50:1 two-stage VP (the max it's rated for) and then into a two-stage spur gearbox. That will result in a max reduction of 672:1. So in summary, yes you should be able to get a 200:1 reduction, it just takes more space than a VP. But, since it's (probably) rated for those high loads, it shouldn't explode every time you try to use it. P.S. - All these huge reductions are theoretically possible, but are practically limited by the max torque capability of the shaft. I'm too lazy to look up the max torque rating but I'm sure it's online somewhere or other. P.P.S. - VPs with a CIM input are rated for a max of 50:1, and only with a 1/2" hex output shaft. I'm not surprised a CIM through a 200:1 reduction exploded. |
Wow I don't know how I messed up so badly on that. I take back everything I said in that last post (except the thing about VPs not being rated for a CIM at 200:1). Yes, you should exceed a 200:1 ratio on the 4th stage. With the 60:12 chain reduction, you can do it in 3 stages. With the 50:1 VP reduction, you can do it in 2 stages. With both the 50:1 VP and 60:12 chain reduction, you can do it in one stage.
#11
We used Bag motors, which vex rates up to 300:1 if you stack the stages in the right order. That said, we found the VP assembly pretty unreliable at the limit of the torque "rating", so your point stands.
#12
Sure, it's a stress point... but is it really that big of a deal? We've used some AndyMark Toughbox Nano's in several applications (including drive train) without any issues at all, and they use retaining rings. In fact, we have one pair of Nano's that's made it through two seasons on two separate robots, with a season in between where it was used for practice. That experience would seem to indicate that using retaining rings may not actually be all that bad.
#13
In this application - can you just have bearing / gear / bearing on the inside of the tube, and shaft retention handled elsewhere? That would require an inner width of only .75, which lets you use 1" wide .125 wall tubing. |
