Go to Post I cannot inspire greatness with mediocrity! - Jim Zondag [more]
Unread 24-08-2016, 17:55
Re: pic: Modular Gearbox
Originally Posted by Ari423 View Post
The big upside of planetary gearboxes is their huge reductions in small packages. Compared to the maximum 10:1 stage on a VP, the biggest reduction you can get from a spur gear stage with this system is 4.5:1 (9:1 over two stages using a combination of 3/8" and 1/2" gears). That would mean using only spur gear reductions to get up to 200:1 you would need 45 stages, or about a 4 ft wide gearbox.
You're not doing that calculation correctly. Gear ratios are multiplied, not added, so if you stacked 4 stages you would get a 4.5 * 4.5 * 4.5 * 4.5:1 ratio, which is about 400:1. Using a chain reduction for the last stage would give you even more.
Unread 24-08-2016, 18:06
Ari423's Avatar
Ari423 Ari423 is online now
FRC #5987 (Galaxia)
Wow I don't know how I messed up so badly on that. I take back everything I said in that last post (except the thing about VPs not being rated for a CIM at 200:1). Yes, you should exceed a 200:1 ratio on the 4th stage. With the 60:12 chain reduction, you can do it in 3 stages. With the 50:1 VP reduction, you can do it in 2 stages. With both the 50:1 VP and 60:12 chain reduction, you can do it in one stage.
2017-present: Mentor FRC 5987
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
