Using a 775pro in Dusty Conditions
Since the 775pro is a fan cooled motor, is it possible to run it in very dusty conditions? For reference it would be used on a mining robot built for NASA's Robotic Mining Competition. The mining material is called regolith (not the horrible FRC kind) and it is made up of very small particles of volcanic ash called BP-1.
We are thinking about using a system of fans and filters to keep the motors cool and sealed. The logic behind using a 775pro or just a fan cooled motor in general is the weight savings vs. a cim motor for example. So can a 775pro survive these conditions? Is this a stupid idea? Does anybody have any motor recommendations that would be better suited than the 775pro? |
Re: Using a 775pro in Dusty Conditions
Not a pro, but I have used a 775 (RS-775-18) in the same competition. Used drink cans (empty, of course, and missing one end...) around the back end of the motors and plenty of tape to seal the dust out. No motor problems, but the speed controller safeties gave us trouble... (not motor-related). This was in the drivetrain; I want to say I uploaded a photo to CD-Media some time ago of that robot. There was no cooling on the robot--remember that there is no air on the moon, so fans aren't exactly useful (FRC 2009 aside). Judges just might call ya on that.
I'm not sure I'd use a 775-Pro in that application, offhand, but if it seems to work out powerwise that might do the trick. Last edited by EricH : 08-29-2016 at 11:56 PM. |
I think it would work, but it may not last long if dust stops the fan or impedes airflow. Motors will work if they're filled with dust, but they will probably run hotter. How fine is this dust? Maybe you could put a screen or filter over the 775's vents and just clean it every run. Is there anything electrically conductive in the dust?
Oh, and the robots get vacuumed on exiting, trying to get all of the dust off or out. I don't think there's anything conductive, but it's hard to say for sure. |
Thanks for all the advice Eric! Good to know there is precedent for something like this. We'll obviously do some testing before implementing anything.
The 775pro is just such a powerful motor for the weight that I think it's worth the trouble to filter and cool it. Given how fine the BP-1 is, would filtration even be possible? I haven't taken the time to look into that yet. Also, NASA allows fan cooled motors despite the fact that there is virtually no atmosphere on the Moon/Mars. This is because NASA can afford much nicer motors than us ![]() |
If I were you I would venture into brushless land, an Inrunner is already sealed, or an outrunner doesn't really care that much, but could be sealed without too much work.
-Aren |
Is power important or is it more weight reduction that you are wanting? If you wanted to reduce weight and don't need a lot of power a small sealed motor like a BAG motor could work. Last edited by pilleya : 08-30-2016 at 12:54 AM. |
#10
Let me brutally honest about this from our competition experience down at Kennedy in '13. They will not survive past the competition unless your motor enclosures are above excellent. See my link below about this.
https://www.youtube.com/watch?v=DaodHQC_MIo We had an enclosure that was large enough to allow for some air to move around our rs775s but you will not have that in a lunar/martian environment. In testing, we wrapped our motors in several different materials but even with sand we had thermal issues because heat was being generated quickly in those wrappings. We ended up going with enclosures that had dust barriers around the drive shaft. The encoders we used were also protected with an enclosure that was a bit taller if you look in the video. We had to replace 3-4 motors out of 6 because this material is so fine that it actually went through two military grade dust barriers and into the motor. I would recommend using CIMS if possible because if any of that dust gets in the rs motor it is done for. We even had melted fans in the motors. If we had the weight we would have went CIM motors for sure. The challenge is a lot harder than it looks. We qualified in 6th place I think which was the first time UNCC ever qualified. Also, do not get that stuff on your skin!!!! Clean your rover really well when you come out. |
#12
Pneumonoultramicroscopicsilicovolcanoconiosis. Be careful. |
#13
Do robots really get diseases from inhaling fine volcanic ash? Huh.
#14
Is this the disease you get if you try to pronounce that word?
#15
It isn't that hard to pronounce. You just have to break it up into parts: pneumono + ultra + microscopic + silico + volcano + coniosis Alternatively, you could just say silicosis, which is a synonymous term. |
