Go to Post Although I'm 2-0 against 217 when Paul coaches, I'm 0-2 against them when he doesn't....hmmm.... :rolleyes: - Lil' Lavery [more]
Unread 08-09-2016, 09:29
Mike Schreiber's Avatar
FRC #0067 (The HOT Team)
Re: paper: Stop the Stop Build
Originally Posted by ThaddeusMaximus View Post
orrrrrrrrrr get rid of 120lb weight limit so parts can be designed for infinite fatigue life and still be viable?
Not to get too off topic but interesting point
How do you plan to carry the robot to the field?
Originally Posted by The National Institute for Occupational Safety and Health (NIOSH)
...the maximum weight to be lifted with two hands, under ideal conditions, is 51 pounds
Source
FIRST already pushes this limit since we are usually lifting from the ground and load capacity is generally reduced to about 80-90% during a two person lift since the weight isn't exactly split by 50% at all times.
Mike Schreiber
Unread 08-09-2016, 19:39
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
First off, Jim thank you for putting this together, it's an excellent read.
The middle ground proposal is a very good step in the right direction. The only thing it doesn't easily allow for is teams to hold scrimmages on weekends when they aren't competing. In this proposal it is still advantageous to compete more often during the season. This becomes less of a problem once all areas are in districts as competing additional times is less expensive and you are already competing more often. For teams that are not in a district system I could see how having more than 8 hours of ROBOT ACCESS time would be needed to get the full benefits of what a practice bot currently allows.
At that point we are just changing a single variable, I do strongly agree with the plan in general.
Unread 08-09-2016, 20:45
NShep98's Avatar
NShep98 NShep98 is offline
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 is on a distinguished road
This is actually where my confusion came in as to how this would interact with the current District Access Period, because the point of districts getting extra time is to offset the additional day regionals get.
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
Unread 08-09-2016, 21:09
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Perhaps with this proposal Regional Events could start their matches after lunch on Thursday, allowing more time for more matches.
Collin Fultz
Unread 08-09-2016, 21:41
EricH EricH is offline
Someone just made that suggestion in the other thread. We can do that, provided that we get a district schedule as far as load-in/inspection. That is, we start load-in/inspection at 5 PM Wednesday, practice Thursday morning, and pray that enough refs make it by noon to start.
Sound reasonable?
Now do that with a 40-team regional. You're only adding another half-day of matches, so that regional now gets about 16 matches/team, more than any district, before elims. What was that about district events giving more plays than a regional? (Or else you add massive downtime/slow cycles.) Oh, you don't like that part of it. So you're going to have two regional schedules, one for large and one for small. How confusing will that be?
Remember, Thursday from noon to 6 is practice matches at regionals. And some teams can't even make their last scheduled match (or the filler line) and have to come to the field later to connect robot to field. In order to speed that up to be from 9 to noon or so, the regionals are going to need extra inspection time on Wednesday evening, particularly large early-season regionals.
Unread 08-09-2016, 21:45
PayneTrain's Avatar
PayneTrain PayneTrain is online now
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Sound reasonable?
Yes, because regions are already doing that right now.
16 matches for $5000 still comes out behind districts offering up 24 at the same price. Regionals follow the same schedule template handed down to them from Manchester, but without any cap to a regional outside of physical space in the venue, very few regionals are exactly alike.
Unread 08-09-2016, 21:53
PayneTrain's Avatar
AKA: Lizard King
Team Role: Mascot
I also want to add that while I do not speak for Collin, I believe he is a former FRC Team Advocate at FIRST HQ and the current president of IndianaFIRST. I imagine he would like whatever we can try out to improve the team experience.
Unread 08-09-2016, 22:04
Your Wednesday "inspection" at a regional is "Here's the green tag saying you can open the bag tomorrow morning, be safe setting up your pit". (Or you get the dreaded "red tag": See the LRI to clear the lockup form, withholding, or other "oops".) Same as the Thursday "early load".
Districts are doing inspection on load-in night. Champs is doing inspection at uncrate. Regionals? Sign form, check withholding and bag integrity, and make sure that no work is done on the robot.
Unread 08-09-2016, 22:08
PayneTrain's Avatar
AKA: Lizard King
Team Role: Mascot
I occasionally use the word "region" to describe an area in district events. Regionals are independent of a region.
Let me amend: events in FIRST at a size equivalent to a regional already do what you have described.
Unread 08-09-2016, 22:24
And no (actual) regionals do that. I'm sure the teams could adjust (well... MOST of the teams, I can think of a few that are probably not going to catch the change easily), and the volunteers can probably adjust. Assuming that FIRST decided to make such a change.
BTW, just as a thought: If the context is going to make it confusing to use "region", such as above, it may be worth it to use a different term, as "region" can make some people think you're misspelling "regional". Just for the sake of clear communications. I often use "district area" to describe an area that runs district events, myself.
Unread 08-09-2016, 22:02
In 2016, around 64% of Regional teams only attended one event. 16 Qual Matches at a Regional where around 2/3 of the teams there will only compete on that weekend sounds pretty great!
Collin Fultz
