Re: paper: Stop the Stop Build
First off, Jim thank you for putting this together, it's an excellent read.
The middle ground proposal is a very good step in the right direction. The only thing it doesn't easily allow for is teams to hold scrimmages on weekends when they aren't competing. In this proposal it is still advantageous to compete more often during the season. This becomes less of a problem once all areas are in districts as competing additional times is less expensive and you are already competing more often. For teams that are not in a district system I could see how having more than 8 hours of ROBOT ACCESS time would be needed to get the full benefits of what a practice bot currently allows. At that point we are just changing a single variable, I do strongly agree with the plan in general. |
This is actually where my confusion came in as to how this would interact with the current District Access Period, because the point of districts getting extra time is to offset the additional day regionals get.
Perhaps with this proposal Regional Events could start their matches after lunch on Thursday, allowing more time for more matches.
Sound reasonable? Now do that with a 40-team regional. You're only adding another half-day of matches, so that regional now gets about 16 matches/team, more than any district, before elims. What was that about district events giving more plays than a regional? (Or else you add massive downtime/slow cycles.) Oh, you don't like that part of it. So you're going to have two regional schedules, one for large and one for small. How confusing will that be? Remember, Thursday from noon to 6 is practice matches at regionals. And some teams can't even make their last scheduled match (or the filler line) and have to come to the field later to connect robot to field. In order to speed that up to be from 9 to noon or so, the regionals are going to need extra inspection time on Wednesday evening, particularly large early-season regionals. |
I also want to add that while I do not speak for Collin, I believe he is a former FRC Team Advocate at FIRST HQ and the current president of IndianaFIRST. I imagine he would like whatever we can try out to improve the team experience.
Your Wednesday "inspection" at a regional is "Here's the green tag saying you can open the bag tomorrow morning, be safe setting up your pit". (Or you get the dreaded "red tag": See the LRI to clear the lockup form, withholding, or other "oops".) Same as the Thursday "early load".
Districts are doing inspection on load-in night. Champs is doing inspection at uncrate. Regionals? Sign form, check withholding and bag integrity, and make sure that no work is done on the robot. |
Let me amend: events in FIRST at a size equivalent to a regional already do what you have described. |
BTW, just as a thought: If the context is going to make it confusing to use "region", such as above, it may be worth it to use a different term, as "region" can make some people think you're misspelling "regional". Just for the sake of clear communications. I often use "district area" to describe an area that runs district events, myself. |
#10
In 2016, around 64% of Regional teams only attended one event. 16 Qual Matches at a Regional where around 2/3 of the teams there will only compete on that weekend sounds pretty great!
