Go to Post ROBUST, ROBUST and ROBUST if you want to win - dan 322 [more]
Unread 08-09-2016, 22:08
PayneTrain's Avatar
PayneTrain PayneTrain is online now
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Re: paper: Stop the Stop Build
Your Wednesday "inspection" at a regional is "Here's the green tag saying you can open the bag tomorrow morning, be safe setting up your pit". (Or you get the dreaded "red tag": See the LRI to clear the lockup form, withholding, or other "oops".) Same as the Thursday "early load".
Districts are doing inspection on load-in night. Champs is doing inspection at uncrate. Regionals? Sign form, check withholding and bag integrity, and make sure that no work is done on the robot.
I occasionally use the word "region" to describe an area in district events. Regionals are independent of a region.
Let me amend: events in FIRST at a size equivalent to a regional already do what you have described.
Unread 08-09-2016, 22:24
EricH EricH is offline
And no (actual) regionals do that. I'm sure the teams could adjust (well... MOST of the teams, I can think of a few that are probably not going to catch the change easily), and the volunteers can probably adjust. Assuming that FIRST decided to make such a change.
BTW, just as a thought: If the context is going to make it confusing to use "region", such as above, it may be worth it to use a different term, as "region" can make some people think you're misspelling "regional". Just for the sake of clear communications. I often use "district area" to describe an area that runs district events, myself.
