Go to Post My wife said if no one gets ahead no one gets left behind. - Koko Ed [more]
Unread 09-09-2016, 03:19 PM
Bill Klein Bill Klein is offline
FRC #3688 (Norsemen Robotics)
Bill Klein is a jewel in the roughBill Klein is a jewel in the roughBill Klein is a jewel in the roughBill Klein is a jewel in the rough
pic: Team 3688 Lexan Line Bender 12 volt
Unread 09-09-2016, 03:20 PM
Eric Scheuing's Avatar
FRC #0999 (MechaRAMS)
Re: pic: Team 3688 Lexan Line Bender 12 volt
This is cool, especially with the construction video. Thanks for sharing! I actually need something similar to this for work... you may have helped me save a good chunk of my project budget
2015-20XX: MechaRAMS 999
Unread 09-11-2016, 08:17 AM
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Can you post a few lines on how you use it?
How do you hold the plastic in place? Do you use a form/guide to give it the curve you want?
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 09-11-2016, 11:37 AM
chapman1's Avatar
chapman1 chapman1 is offline
FRC #3688 (Suttons Bay Norsemen Robotics)
chapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond repute
Sure!
First, though, a note about heat: The nichrome wire should glow orange-red when it's hot enough. If it doesn't get there, then either the voltage is too low or the wire (a resistor) is too long for the available voltage (ohm's law).
OK: the acrylic/plexiglass/lexan is placed over the wire channel, as shown in the photo. For a sharp, consistent bend, (and for small pieces) it's sometimes helpful to place a piece of wood on the half that will not move during the bend.
Depending on thickness, it can take a half minute or more to get hot enough to bend. You'll know. If you try too soon, you'll get an uneven and unpredictable bend; if you wait too long, the plastic will bubble and get thin, decreasing its strength.
When ready: if working alone, disconnect the power supply and quickly fold the hinged half up to the desired angle. Hold it there until the plastic has cooled and regained strength. If not working alone, then you can take a bit more time making the bend and then have someone disconnect the power while you hold the bend.
Pretty simple, really. Still, it's a good idea to practice on some scrap pieces first.
BTW, this thread had it's origin in "Uses of Lexan": https://www.chiefdelphi.com/forums/s...d.php?t=150980
Unread 09-11-2016, 12:14 PM
chapman1's Avatar
As mentioned in the mother thread, this video served as our inspiration:
https://www.youtube.com/watch?v=yT9EXnmRpHs&t=0s
I just noticed that in the comments accompanying it, the author posted a video of it being used:
Unread 09-11-2016, 02:00 PM
Acrylic and Polycarbonate (Lexan) are two very different materials, and bend in very different ways. For acrylic, this technique works very well. However, acrylic is brittle and prone to cracking, and I cannot think of any application where it would be suitable in an FRC robot.
Polycarbonate on the other hand is very resilient. We simply bend it on a sheet metal brake, cold, just as you would metal, and it comes out great. You just have to overbend to compensate for the spring back.
Unread 09-11-2016, 02:13 PM
Sperkowsky's Avatar
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
We do something similar although we actually heat a line first and then bend with our brake. It makes a perfect bend every time. We use one of these http://www.delviesplastics.com/p/Stripheater.html but you can obviously just build something like 3688 did.
Unread 09-11-2016, 07:06 PM
chapman1's Avatar
Excellent! We'll bring a sheet metal brake with us to our next competition
Unread 09-11-2016, 08:55 PM
Thanks for the help!
Unread 09-11-2016, 09:31 PM
SeeleySWS's Avatar
SeeleySWS SeeleySWS is offline
Person To Blame
AKA: Spencer Seeley
FRC #3688 (The Norsemen)
Team Role: Operator
SeeleySWS has much to be proud ofSeeleySWS has much to be proud ofSeeleySWS has much to be proud ofSeeleySWS has much to be proud ofSeeleySWS has much to be proud ofSeeleySWS has much to be proud ofSeeleySWS has much to be proud ofSeeleySWS has much to be proud ofSeeleySWS has much to be proud ofSeeleySWS has much to be proud of
We don't have the resources for a sheet metal bender... But this bender cost us very little and serves us well. Being portable doesn't hurt either.
Also, we use our acrylic supply to test our ideas before using the precious lexan.
Unread 09-12-2016, 12:09 AM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Once you understand the difference between acrylic and lexan, why do you let any acrylic within a mile of your build site? It can only end in tears.
Unread 09-12-2016, 01:13 AM
troy_dietz's Avatar
troy_dietz troy_dietz is offline
3D printing and Alliance Captain
FRC #0330 (The Beach Bots)
Team Role: Human Player
Rookie Year: 2015
troy_dietz is on a distinguished road
I've heard of teams prototyping with lasercut acrylic because polycarbonate absorbs infrared radiation and can be a pain to cut. Acrylic is usually cheaper and just as easy to find.
Unread 09-12-2016, 08:21 AM
z_beeblebrox's Avatar
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
If you've got a laser cutter, plywood cuts great and is way cheaper than acrylic. And it's lighter and more resilient, so you can make your whole robot out of it.
The lexan bender is really cool though.
Unread 09-12-2016, 11:14 AM
SeeleySWS's Avatar
Person To Blame
AKA: Spencer Seeley
Team Role: Operator
It's only for prototyping shapes and never gets stressed or used in a competition. We use it because we have it.
Unread 09-12-2016, 11:21 AM
Data Nerd
FRC #0079
Still useful for non-contact display items. Example - laser cutting team awards. Less uses but certainly still viable as a material.
