Go to Post Don't ever give up on your robot, especially this early in the season. That robot is what you make of it. If you give it your all, something good is bound to come your way. - Amanda Morrison [more]
Unread 14-09-2016, 19:20
Munchskull's Avatar
Munchskull Munchskull is offline
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Re: pic: 2.5in gearbox
Originally Posted by Mechvet View Post
Looks good so far!
What led to your choice of 2.5" colsons?
What gears are you using? I ask this because at smaller tooth counts for a more compact gearbox, you *might* be approaching the limit for some materials, such as aluminum. (note: I have done zero calculations for a smaller box. I'd suggest running some lewis gear numbers to see if you're inside the gear's envelope)
Am I correct in assuming that the two sprockets inside the gearbox mean this is for a WCD setup? If that's the case, how are you planning to mate this gearbox to the frame rail?
The gearbox would be mounted using the lower 10-32 bolts that would mount the CI'M motors, in total there would be 3 10-32 bolts holding the CIM motors and the gearbox on.
I used 2.5" where's because my personal philosophy is that the smaller the wheel you design for the small your gearbox can be. I posted this because I fear I am missing some torque related risks of small wheels.
The chain is #25 because small wheels should (if I did my math right) require less torque to move and rotate.
Are there any disadvantages of 2.5in wheels I may have missed? (assuming that high centering is not an issue)
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 14-09-2016, 20:02
Cothron Theiss's Avatar
Possibility of getting caught on field elements or uneven flooring notwithstanding, a concern when using really small wheels is tread wear. If you think about it, 2.5" wheels are traveling the same distance with much less tread. Now the Colsons are wonders for durability, but they will still wear down pretty quickly and become slicker sooner. But if it's a WCD setup, you should be fine to replace wheels often.
Unread 14-09-2016, 20:13
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Doesn't that mean that you would have to assemble the gearbox directly onto the drivetrain, instead of assembling it somewhere else and mounting it on? That would be more annoying imo. From what I can see, there's space to add some mounting holes and avoid that complication.
Unread 14-09-2016, 20:41
It looks like the gearbox can be assembled off-bot, but you attach it using 1 screw each from 2 CIMs. I like this design; that's a really good use of screws.
Unread 14-09-2016, 22:07
Munchskull's Avatar
It can but partial disassembly will be required to install.
Anthony Cardinali
4th year of FRC
Class of 2017
