Go to Post Way to steal my thunder, Billfred! :p - Koko Ed [more]
Unread 27-09-2016, 13:04
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: pic: Piston-in-Tube Concept
Isn't a pneumatic cylinder on its own already a piston-in-tube device?
You could shave some weight off if you used a bracket to secure a tube to the nose of the cylinder so that only the piston rod is enclosed. You might need to rethink mounting, but the weight saved would be non-negligible. In addition, it could be argued that such a design would be more faithful to the name.
