Go to Post Don't fix mechanical problems with software, ever. - Chris is me [more]
Unread 28-09-2016, 08:57
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Re: pic: Wheeled shirt launcher
Slight resurrection, but I'm curious - has your team moved forward with this project?
We are also looking at wheeled t-shirt launcher designs as an offseason project (and practice for the upcoming American Football game), and there simply aren't many to be found.
Hi!
Unread 28-09-2016, 14:59
D.Allred's Avatar
D.Allred D.Allred is offline
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
We built one last year similar to the OP's design with a few key differences. We used a cylinder to push the shirts into the wheels. We also had a pvc pipe on the shooter to keep the shirts straight. There are slots in the side of the pipe for the shooter wheels.
Here's a brief tour of the shooter.
https://youtu.be/SnaXhoxGsy0?t=8m1s
What information do you need?
David
Unread 29-09-2016, 14:25
Taylor's Avatar
AKA: @taylorstem
At this point, we are most interested in your launcher wheel RPM and the optimal compression on the shirts. I think we can puzzle through the rest.
Hi!
Unread 29-09-2016, 14:50
2791 briefly built a prototype of a wheeled T-shirt shooter in late 2014, and I think they found that marshmallow wheels ("Sure-Grip Drive Rollers" on McMaster, Buna-N) were the best wheels for shooting T-shirts. The compliance helps deal with small variances in shirt packing density or size, and it imparts more energy into the shirts. I would give those a try.
Unread 29-09-2016, 17:09
inorbert inorbert is offline
Build Captain and Driver
FRC #5811 (BONDS)
Rookie Year: 2016
inorbert is an unknown quantity at this point
I need to get pictures from my teammates but 5811 built a t-shirt shooter prototype and were able to get roughly 38 yards out of it. We used 2 6" andymark wheels with 2 timing belts to feed into it
Sent from my LG-D851 using Tapatalk
Unread 29-09-2016, 23:05
nuclearnerd's Avatar
AKA: Brendan Simons
FRC #5406 (Celt-X)
We built the a test version of a wheeled shooter this summer with Andymark 8" wheels, and VEX clamping gearboxes. See here: https://goo.gl/photos/hjbNw8vYjDLF34nG9. After a bit of iteration (added a second stage, and reduced compression to only about 1") we got it shooting about 75 ft. There's still a bit of work to do before we can mount it on a robot (and I think we can tweak it to shoot further) but we might use the test version as-is as a "T-shirt mortar" into the stands at this fall's STEMley Cup
Unread 29-09-2016, 23:30
For something like this, it would probably be a lot better and cheaper to buy some Brushless outrunners and brushless ESC's rather than try to keep to FRC legal parts only. Your spinning a flywheel in one direction at highspeed so it's basically perfect to be made Brushless.
Unread 30-09-2016, 09:36
It really wouldn't, though. Even assuming they don't reuse old parts, a CIM is $27 and a Spark is like $45, which together is comparable to or cheaper than a 12V 300W brushless motor. You can get non-reversible PWM speed controllers for brushed motors for less than the cost of common FRC reversible controllers.
Edit: I didn't see they were feeding the CIM through a VP, which I honestly think they could skip if they wanted and just cantilever the wheels off CIM shafts with hex adapters. Kind of sketchy but it would be fine for an offseason robot.
Unread 30-09-2016, 10:49
Data Nerd
FRC #0079
I'm gonna ignore the cost argument. But I'd have concerns if your shooter wheels had any significant mass. There'd likely be some reconfiguring of the ESC required to get it working without starting a small fire.
DC motors can be abused and, given how students tend to do things, that's a good thing. I'd stick with maybe some 550 motors and appropriate VP gearboxes if required.
Unread 30-09-2016, 17:00
NWChen's Avatar
NWChen NWChen is offline
Alum
NWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to behold
We (the two of us, no longer our team ) have achieved 60-70ft running 6" Colsons directly off MiniCIMs. Compression is a huge factor. Refer to this thread for more information:
https://www.chiefdelphi.com/forums/s...d.php?t=149446
Video should be up soon, since we'll be at Maker Faire NY this weekend.
2012 - 2015 • Team 2601
Unread 30-09-2016, 17:20
Sperkowsky's Avatar
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
See you there! Will be very interested to see what you built in action.
Unread 02-10-2016, 06:04
FRC #5811 (BONDS)
Rookie Year: 2016
Took a bit but here is ours, you cannot see where the t-shirt lands but it is about 115 feet away. The front two wheels are each powered by a CIM and the belts in the back are each powered by a Mini CIM. We couldn't keep testing because we lost the key to one of the mini-CIMs and don't have any extras
Unread 02-10-2016, 13:52
NWChen's Avatar
Alum
One of several videos from Maker Faire. We estimate about 70ft in the air. The compression of the shirt is very important (our best shots were made with very tightly rolled shirts).
