Go to Post I heartily applaud FIRST for finally reacting proactively to this ongoing problem. - Ether [more]
Unread 06-10-2016, 15:11
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: pic: Vision Aim Ping Pong Ball Robot
For scorekeeping,
Detecting when an IR beam is blocked by a ball that falls into a funnel and then into a "detection pit" should be pretty easy (As easy as anything is in these situations).
To account for changing ambient light, instead of looking for a single pair of blocked/unblocked values, you could turn the IR transmitter on/off frequently, and keep track of the changes in received signals (when they stop changing, the beam is blocked (or the receiver is saturated)).
Blake
