Go to Post There is no right or wrong way to do this. - nuggetsyl [more]
Unread 10-07-2016, 10:05 PM
Osseus_Dominum's Avatar
Osseus_Dominum Osseus_Dominum is offline
FRC #4468
Osseus_Dominum is on a distinguished road
pic: High Traction Drivetrain Concept
Unread 10-07-2016, 10:06 PM
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Re: pic: High Traction Drivetrain Concept
That looks great! How heavy is it, and about how much would it cost?
Unread 10-07-2016, 11:03 PM
FRC #4468
Weight is about 38lb without chain (I haven't decided weather this would need #35 chain or it #25 would be sufficient). I think cost would be around $1000 with the 3 CIM gearboxes (haven't done a precise calculation).
Unread 10-08-2016, 12:03 AM
ThaddeusMaximus's Avatar
ThaddeusMaximus ThaddeusMaximus is offline
Thaddeus Hughes
FRC #4213 (MetalCow Robotics)
ThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the rough
Great, now I'm thinking about lawyering the rules to use differently-sized pool noodles which make wedged bumpers...
Formula SAE is now the thing I do. #becauseRacecar
But I'll still be a mentor for like, forever.
Check out what I'm up to: http://ppi.ddns.net/blog
"So, wait, what kind of engineer are you? Mechanical? Electrical? Software?"
"Yeah pretty much."
Unread 10-08-2016, 12:09 AM
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is offline
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
2016, R21.C
Blue box from that rule:
All pool noodles used on a ROBOT must be the same in order to
maintain the desired interaction between ROBOTs in the cases of
BUMPER-to-BUMPER contact. BUMPERS containing pool noodles
of vastly different construction may cause a “ramp” effect when
interacting with other BUMPERS.
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
Unread 10-08-2016, 12:18 AM
Does that 38 lbs include the battery? 38 sounds a little heavy, but that may just be the 8 wheels and the relatively heavy gearboxes and motors. I would suggest you look at JVN's design calculator to figure out your gear ratios. You're designing this drivetrain to win pushing matches, so you'll need to make sure your low gear is low enough that your motors don't burn out.
Also, you may want to push the Colsons on each side out to the front and back of the chassis. Your inner wheels are quite close together, and while the Omni's will cause some turning scrub, you may find this still turns too quickly for your driver's comfort.
If you want to drop your price point on this, you could look at a different (custom?) gearbox. You could also consider switching to smaller wheels for the purpose of using the 3.25" Omni's that already have the hex bore. This will save about $12 per wheel since you don't need VersaHubs. There are other small things here and there you can do to lower the cost without increasing the need for machining much.
Also, I see no reason not to use #25 chain.
Unread 10-08-2016, 12:30 AM
Steven Smith Steven Smith is offline
FRC #3005 (RoboChargers)
Steven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond repute
You might consider looking at this post, it's for VEX but concepts apply.
Vex Forums
Not to discourage you, it's great to see people looking and figuring things out for themselves, but most combinations of "what happens if I put X wheel in Y position" have been pretty thoroughly looked at for tank drivetrains. You are just left with a bunch of trade-offs, and the magic is in selecting the right drivetrain for what you need it to do, not necessarily trying to find a magic drivetrain that is far superior in all cases.
In this case, let's compare to a 4 wheel omni (basically take out your center wheels), an 8 wheel omni, and an 8 wheel tank.
Increasing the number of wheels is usually a factor of what you need to traverse. More wheels reduces the amount of space between the wheels, allowing it to claw over. Additionally, by staggering the drop of the wheels, such as in a 6 wheel drop center (or 8... 10... 12... whatever), you can trade off stability (rocking) for reducing turning scrub. Adding more wheels can also give you a little more "middle stability" in the neutral state.
An omni wheel already has pretty good traction in the forward direction, and can push fairly well. What it doesn't have is any resistance to lateral movement. If you look at a 4 wheel omni drive (like the 2014 JVN buildBlitz, or any number of other ones), it almost drives like a drifting car. With drive practice, you can do some interesting things to throw it around... but you are also at a higher risk of being spun.
So to your drivetrain, you have a risk if the omni wheels are preferentially weighted (design tolerances, weight shift under acceleration) of acting more like a 4 wheel omni drive. You probably don't have substantially more pushing power than an 8 wheel omni drive, but you have a little more resistance to being pushed sideways... while still more at risk of being spun. So basically, you have a set of tradeoffs that gives you some of the benefits of a 4 wheel omni and some of the benefits of an 8 wheel drop center tank, some of the disadvantages of either, etc. At the risk of beating this horse dead, I just want to emphasize that you don't get the advantages of both as well as dodging the disadvantages of both, it is just a blend.
That being said, depending on the year, it might all be a valid set of trade-offs and lead to a pretty solid drive train. Build it and see what you think
Edit: Also as a note, I'm not sure how significant the "lower bumper" comment is. Most drop drive trains (outside of pneumatic wheel years like last year) are on the order of 1/16" to 1/8". When you are talking about a several inch bumper contact patch, I think the drop center difference will be lost in the noise when compared to other variables (bumper construction, driver practice) when you talk about defensive play. (just imho)
2013 - 2016 - Mentor - Robochargers 3005
2014 - 2016 - Mentor - FLL 5817 / 7913
2013 - Day I Die - Robot Fanatic
Unread 10-08-2016, 12:36 AM
I think you will have a hard time trying to find a 3.25inch Colson, let alone a 1/2 inch hex bore one.
This isn't exactly new; this wasn't an uncommon layout in 2010 and later when 8WDs started gaining traction.
In short these have similar results to a 2 traction 4 omni setup vs a 6WD. Most of the problems "solved" by this drive are minuscule / imaginary. Rock shouldnt be big enough to be the difference maker in a bumper to bumper pushing match; we are literally talking about a 1/16th inch difference in bumper height here. The omni wheels lower resistance to being spun more than the 8WD all traction designs do given the same wheel layout. Omnis also don't match the lateral traction of Colsons or traded traction wheels, so you're giving up a little there.
Basically, you need a really good reason to not have a drop center for this to be the right call. Given that an unequal spaced 8WD already doesn't do much rocking at all, it's hard to find a niche for this drive.
Unread 10-08-2016, 01:03 AM
FRC #4468
Do hou have any pictures of 8 wheel drives like this? I haven't been able to find any.
Regarding your concern about lateral traction and being pushed or spun, I don't see how this would be any more at risk. An 8 colson wheel drivetrain with center drop will only ever have 4 colsons giving traction at any one time, just like this drivetrain. So why is this more susceptible to spins?
Unread 10-08-2016, 01:30 AM
EricH EricH is offline
A "proper" setup for an 8-wheel with center drop will often have the outer 4 skimming the carpet. There's considerable sideways "traction" available if you're hit--more particularly if the impact rocks you "onto" the end being hit. With omnis, you have zero sideways traction available in that situation. It's not that they aren't skimming the carpet, it's that they're omnis. They're designed to allow free sideways motion.
Of course, maybe you shouldn't just trust my word for it. Weight up a proto-frame set up for 8WD (you can just have the 8 wheels on a frame) in one of your favorite configurations--you want 150 lb or some considerable fraction of that weight. Try to turn it by pushing it, hitting it, etc. Swap wheels and repeat. Quantitative data may be harder to get than qualitative, but you should be able to get an idea of how the robot will try to act.
Unread 10-08-2016, 10:07 AM
bstew's Avatar
bstew bstew is offline
FRC #3928 (Team Neutrino)
Rookie Year: 2015
bstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to behold
1986 used a drive like this in 2014. A video of just the drivetrain is located here. There are certainly many other examples, but this is the one that comes to my mind.
Unread 10-08-2016, 10:51 AM
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Mounting your bumpers as low as possible and limited rock is an excellent way to gain traction in a pushing match, and something 558 does as well. Where we differ is that if we are designing for maximum pushing force we believe that any wheel that touches the ground should be a traction wheel. Understand that any wheel that is in contact with the ground is providing traction, and increasing the number of contact points with the ground reduces the normal force on each wheel. Typically 558 will design an 8wd with a larger center to center distance between the middle wheels to increase scrub and make the robot both more stable at speed, and more resistant to spinning.
In basic terms, an 8wd robot with drop center will provide more pushing force than an 8wd with omnis on the outside all other things equal.
Unread 10-08-2016, 01:01 PM
If accurate, 38 pounds is actually on the lighter side for a 6 CIM shifting drivetrain with wide traction wheels.
Unread 10-08-2016, 01:05 PM
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
By placing omni wheels in the front and rear, you are creating a drive train with what amounts to a very short wheelbase and very wide track.
This will make turning very easy, almost too easy. It may turn out to be a bit squirly to drive.
You may want to consider adding a gyro to assist with driving straight.
