Go to Post I am sad that the Patriots lost, and I am happy for both teams that won...but I am even more thrilled that for the next two weeks robot building in the midwest comes to a standstill. ;) - Jessica Boucher [more]
Unread 10-08-2016, 11:50 PM
philso philso is offline
FRC #2587
Re: pic: High Traction Drivetrain Concept
It may be beneficial to consider what the normal force on each wheel would be and the behaviour of your chassis as it drives over a floor that is not perfectly flat. What happens if the four high-traction wheels in the middle have a slightly smaller diameter than the omni-wheels?
Unread 10-08-2016, 11:52 PM
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Today I saw an FTC robot on Twitter which basically looks a 6-wheel version of OP's model.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 10-09-2016, 02:44 AM
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Originally Posted by Osseus_Dominum View Post
Do hou have any pictures of 8 wheel drives like this? I haven't been able to find any.
Regarding your concern about lateral traction and being pushed or spun, I don't see how this would be any more at risk. An 8 colson wheel drivetrain with center drop will only ever have 4 colsons giving traction at any one time, just like this drivetrain. So why is this more susceptible to spins?
The resistance your robot is going to be able to give is related to the amount of friction your robot has to resist that force. When it comes to lateral force, it's obvious that an omni wheel is going to present negligible friction compared to a traction wheel. Even ignoring the wheel placement for the moment (the outboard wheels will have a greater lever arm to your center of mass for resisting the applied moment), you can determine the friction from your wheels with the equation f=μN. For our purposes here, the normal force is equivalent to the weight placed on each wheel.
When the quantity of wheels in contact with the ground is increased, the normal force on each wheel is decreased (less weight on each wheel). In the case of a 8WD with 4 "drop center" wheels, you'd have the weight of the robot on 4 wheels. 100% of the robots weight would then be placed onto those 4 traction wheels. In your corner omni 8WD, the weight of the robot is distributed among 4 traction wheels and 4 omni wheels. Assuming an even distribution of weight, you'd have 50% of the weight of the robot placed on wheels with a high coefficient of friction, and 50% of the weight of the robot placed on wheels with a low coefficient of friction. As a result, the total friction your robot generates to resist that lateral force would be less than a robot with all of its weight placed upon high traction wheels.
Now, we've made quite a few assumptions to reach this point, and many things will end up being far more complicated in reality than I've presented here. For instance, resisting a spinning moment is going to be very dependent on wheel placement, drop height, and frame interactions. But I wanted to illustrate a general point. To phrase that point differently, the advantages your design has in terms of turning itself easily also serve to make it easier for other outside forces to turn. None of this is to say your design is poor, just that it will behave differently than a drop center drive. In some cases, team's have taken advantage of ultra-low resistance to turning and incorporated it into how they wanted their robot to behave.
Unread 10-09-2016, 12:31 PM
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Thanks for sharing your design! CD needs more of this.
Some quick comments. Unless you adjust the spacers on the Ballshifter third stage I don't believe there is enough room for #35 chain. Remember you want to have clearance on both sides of the sprocket for the chain.
With the 8wd if you switch your chain routes it will allow you to sneak the outer chains in a little making the shafts shorter and save a little real estate in your bellypan.
It looks really solid. Nice work!
1058 PVC Pirates 2016 - xxxx
Unread 10-09-2016, 01:53 PM
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Originally Posted by ThaddeusMaximus View Post
Great, now I'm thinking about lawyering the rules to use differently-sized pool noodles which make wedged bumpers...
I've seen this done before, and it provides little to no real world advantage - ignoring the fact that this is illegal. Bumpers don't seem to be rigid enough to act as an effective wedge, which seems to lead to minimal weight transfer.
As others have noted before, low (literally, the bottom of the bumper zone) bumpers are pretty much all you need if you want to build a drivetrain that's effective at holding it's ground and/or moving objects.
If you really want to have fun, you can start playing with the center wheel spacing relative to the outer wheels, a larger center wheel base will lead to a drive train that has more of a tendency to drive straight while a shorter wheel base will lead to better agility at the expense of straight tracking.
I personally am an advocate for minimal drop on 8 wheel drives. The last two I had direct involvement with had .090" drop (2013) and .060" drop (2014). The difference in drop were due to different strategic objectives and robot configurations but each was somewhat optimized for the role. The 2013 drive train was optimized to sit on the back 6 wheels when in shooting position to provide a stable platform and while in transit position it rocked forward to "tip" the whole robot back for more stable driving and a slightly angled leading edge, helping to get "under" other robots. 2014 was designed to "Squat" when pushing, digging all 8 wheels into the carpet while also providing good stability at speed.
A couple things to remember when chasing high traction performance:
-Wheels sink into the carpet, sometimes as much as 1/8". A drive with minimal drop may not ever have it's wheels leave the carpet, nor does it truly rock, instead the force on each wheel changes depending on the conditions.
-Traction on carpet is a bit more complicated than F=CoF x Fn. There are a series of factors such as carpet wear, tread geometry and tread hardness to consider as some wheels actually "Dig" into the carpet, creating additional mechanical forces that appear to increase traction.
-When working with 6 CIM drive trains, you have to be extremely conscious of current draw, especially when pushing. Once you're pushing another robot, if it's weight begins to transfer to your machine, suddenly a traction limited machine may no longer be traction limited, which usually doesn't end well.
-Dustin Benedict
Unread 10-09-2016, 06:17 PM
Cog Cog is online now
FRC #3324 (The MetroBots)
Cog is an unknown quantity at this point
Just a heads up, those west coast drive clamping hubs are a nightmare to work with. They constantly slip if you use them to hold significant tension on a chain.
Unread 10-09-2016, 06:32 PM
Have you been using the WCP Tensioning Cams?
http://www.vexrobotics.com/217-3431.html
Unread 10-09-2016, 07:28 PM
ThaddeusMaximus's Avatar
ThaddeusMaximus ThaddeusMaximus is offline
Thaddeus Hughes
FRC #4213 (MetalCow Robotics)
ThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the rough
Originally Posted by Jeremy Germita View Post
2016, R21.C
Blue box from that rule:
The trick is you do it ever so slightly.....
Formula SAE is now the thing I do. #becauseRacecar
But I'll still be a mentor for like, forever.
Check out what I'm up to: http://ppi.ddns.net/blog
"So, wait, what kind of engineer are you? Mechanical? Electrical? Software?"
"Yeah pretty much."
Unread 10-10-2016, 02:57 AM
Paul Richardson Paul Richardson is offline
Strategy/Mechanical/Drive Coach
no team (1477/3320)
Paul Richardson has a spectacular aura aboutPaul Richardson has a spectacular aura about
I think there is a fundamental issue with your approach. Many people have tried to solve this problem over the years and I think they're all solving the wrong problem.
What benefit does pushing another robot provide?
On offense, if you engage a pushing match you've done exactly what the defense wants you to do: waste your time. FRC isn't about what you can do, it's about how efficiently you can do it.
On defense, you've placed yourself in your least maneuverable orientation as a tank drive. A good offensive robot will avoid pushing matches and try to just go around to the side. It's hard to move sideways when you're facing forward.
As a defender you have the advantage when you sit perpendicular to an approaching offensive robot. By using your wide side against their narrow side you can be in the wrong spot by a bit and still get in their way. You can react to jukes by just driving straight while your opponent has to turn. It's also really easy to build a robot that's good for this, you just need traction wheels, quick acceleration, and a long wheelbase that's hard to spin. A great driver could play perfect defense without ever touching the other robot just by being in the right spot at the right time.
Now, that works great until they actually do get around you, in which case you still want to slow them down. The majority of robots are still susceptible to the T-bone pin, which almost any drivetrain can do. Just drive into the side of their robot and watch them drive helplessly in circles wishing they had some omni wheels or an angled frame.
Unread 10-10-2016, 05:28 AM
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
In my experience, these sort of drivetrains are susceptible to massive friction loss in a pushing match due to the effects of front-end lifting. For a visible (though somewhat extreme) example of this effect, check out videos from the 2010 game, where bumpers were mounted high.
To reference Lil' Lavery's comments above, in a drive system like this, the weight is distributed evenly between the wheels, however, when you get into a pushing match with another robot (assuming bumpers are the same height), both robots have a tendency to push each other upwards when in any kind of pushing match. On an 8wd robot where the center wheels are lower than the outer ones, the robot simply tilts back onto the rear wheels and maintains traction, but for a no-drop drive system, this effect will result in all of the robot weight being shifted on to you rear wheels, which in this case, have the lowest friction. All other things being equal, this design will likely not stand up in a pushing match with the majority of drop-center 8+ wheel robots, IMO.
Unread 10-11-2016, 05:11 PM
mgreene mgreene is offline
AKA: Mike Greene
FRC #1351 (TKO)
mgreene is on a distinguished road
This isn't exactly new; this wasn't an uncommon layout in 2010 and later when 8WDs started gaining traction.
I see what you did there.
Unread 10-21-2016, 04:30 PM
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Originally Posted by bstew View Post
1986 used a drive like this in 2014. A video of just the drivetrain is located here. There are certainly many other examples, but this is the one that comes to my mind.
We have used this drive arrangement multiple times.
Unread 10-21-2016, 07:20 PM
AKA: Brendan Browne
Care to share what has lead your team to choose this over a normal 8wd with all traction wheels or shrink it down to 6wd?
Do you keep all the wheels on the same plane or do you drop the center traction wheels slightly?
Unread 10-22-2016, 12:40 AM
carpedav000's Avatar
carpedav000 carpedav000 is online now
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
It seems like this issue could be easily remedied by mounting your drive motors/gearboxes (and battery if you have room) to the front of the robot to make it less resistant to shifting onto the back wheels. You could also build a suspension system into the wheels so that when the frame tilts, all the wheels stay on the ground (some might say that this would be too heavy, but you can make suspension systems fairly light ).
It isn't shiny enough.
Unread 10-23-2016, 10:07 PM
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
The weight solution is a good one for pushing matches, but it affects turning in most drives and only works in one direction (often I've found you need to be able to push from either side).
The suspension is also a good solution but far more complex to build.
