Re: pic: SWERRRRVE
Pretty considering the self-imposed limitations.
Revision 1, I'd put the CIMs vertical closer to the center of the triangle. Give some space for frame attachments. |
Re: pic: SWERRRRVE
Looks really good, and I love the packaging more than anything. Looks easy to machine, except the the caster box (what is that made from?).
What made you decide to use a plastic bearing instead of a roller thrust bearing? |
Re: pic: SWERRRRVE
Love the idea of using the clamping gearboxes for the initial reduction. I do have a question. Can you explain why you seem to have an overdrive from the driving sprocket out of the clamping gearbox to the driven sprocket on the wheel?
Also, how thick is the metal on the caster? Tapping threads into the side of sheet metal typically isn't advised. One last thing. How much of a reduction to you have on rotating the caster? Depending on what motor that is, you may need to have more reduction. |
Re: pic: SWERRRRVE
Nice swerve! This reminds me, I still haven't finished mine
One thing, 44 lbs sounds kinda heavy. It appears as if you could shed some weight by designing it to fit on a single sheet of alum/metal of choice (removing the need for the box tubing in the corner) and/or moving your motors closer to the shaft on the caster. |
Re: pic: SWERRRRVE
Did you get any inspiration from the 2468 Versaswerve? I know some of their older designs used similar techniques as yours (clamping box for CIMs, etc.). I think their design would work much better for a more lower resource team. Overall pretty cool design though!
More information here: http://www.frc2468.org/resources, https://www.chiefdelphi.com/forums/s...d.php?t=140942, http://www.vexrobotics.com/vexpro/ex...guides/#Guides Last edited by Roboshant : 15-10-2016 at 21:03. |
Re: pic: SWERRRRVE
I chose to use a plastic bushing instead of a roller thrust bearing mainly because I have worked a good amount with HDPE bushings and have never worked with roller thrust bearings before. From a quick look at what McMaster has to offer, it looks like they would work too. For the speeds this module is spinning at, I have some pretty good real-world tests that say HDPE bushings and bearings work pretty much the same. Quote:
I copied the side-drilled sheet metal design from the Revolution Pro Swerve. The top piece of sheet metal is 3/8" with #10 holes drilled and tapped in the side. That leaves ~.1" of wall on either side of the whole. I suppose I could use #8 instead of #10 screws, if that's not enough. The final reduction on the rotating mechanism is 16.8:1 (7:1 VP and 15:36 chain reduction). With a 775pro, that gives a 90deg rotation in .03s at ~50A. (Using 154lb robot / 4 wheels at 1" arm length in the JVN calc) If that isn't enough, I could easily change the VP reduction to 10:1 or change the driving sprocket from 15t to 12t Quote:
Really, now that I think about it, my design doesn't even need a mill. It just needs an accurate drill press and printouts of the hole patterns. |
