Go to Post To offer an opinion is fine, to demand that others adhere to your opinion is laughable. - JVN [more]
Unread 23-10-2016, 23:24
Scott Kozutsky's Avatar
FRC #0865
Re: pic: CGX-115, cam-counterweighted cycloidal drive
As I understand this mechanism, the cyclodial gear nearest the cim drives against the mounting plate of the cim, which would be fixed against the main structure of the bot. The other cyclodial gear is driving against another plate which is mounted to the arm.
Because both cyclodial gears advance in the same direction, wouldn't this gearbox just provide a powered zero output?
BTW, great work, it's actually because of you that I know that these gearboxes exist at all.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
