Go to Post Not all current students are math dummies. Not all 1960's students were math geniuses either. - Clem1640 [more]
Unread 24-10-2016, 02:50
Sohaib's Avatar
Sohaib Sohaib is offline
AKA: Sohaib Nadeem
FRC #5036 (The Robo Devils)
Sohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of light
Re: pic: Input Stage Wear
Originally Posted by Andrew_L View Post
Could you elaborate more on this? Specifically what the failure mode was, when and how it happened, and whether or not you contacted WCP regarding the issue?
I unfortunately don't have any pictures of this. However, it looked like it was a gradual wear of the thread on the gearbox plate. The threaded holes (when they failed beyond the point at which they could hold the gearbox to our frame) were oval shaped generally in the horizontal direction. (with typical orientation of mounting) In fact, after drilling out the holes for a 1/4-20 tap, the holes were still not perfectly circular, that's how much damage had occurred. We noticed this issue right before eliminations at Fall Fiesta.
We haven't contacted WCP, but plan to do so, along with all of the other issues we have experienced with the SS gearboxes, namely with the CIM mounting.
Something with these gearboxes and oblong shaped holes
Edit: The gearbox on the other side had the same issue shortly after, and has not been repaired yet. When it is disassembled, I will be sure to post a picture, however cannot comment on the failure of it yet as I haven't seen it, it'd be reasonable to assume it is the same failure method however.
2014 Season:
- Drive Coach
- Rookie All-Star Award (GTR-E)
2015 Season:
- Driver
- Deans List Semi-Finalist (GTR-E)
2016 Season:
- Driver
- Alliance Captain (GTR-E)
