Re: pic: Input Stage Wear
As a general rule, talking to the company directly is going to get you further in having your problem fixed/helping the company fix the problem( if there is one) then simply complaining about it on ChiefDelphi.
WCP works very hard to bring good valve and good quality products to the marketplace, and it doesn’t seem right to talk about your problems without a bit more specific detail about each use case and failure mode. Not giving enough detail in the circumstances, could cause teams to get a bad impression of the gearboxes when it was really you pushing the boundaries with how you used them.
If you have enough time to write a post on CD you have enough time to send an email to WCP.
