Go to Post Winning a match is not something a robot does, winning is a team effort that requires the cooperation of dozens of individuals. - Andrew Schreiber [more]
Unread 24-10-2016, 16:14
nuclearnerd's Avatar
AKA: Brendan Simons
FRC #5406 (Celt-X)
Re: pic: CGX-115, cam-counterweighted cycloidal drive
I'm a bit confused, this picture shows a big old mounting flange, but others show the versaplanetary mounting pattern. Did you draw both? I ask because we used 3 stage versaplanetaries this year at 250:1 reduction. We found we were really pushing it with the strength of the hex shaft, and especially the holding power of the two #10 screws. If you've got such a big reduction, consider engineering it to use another output and mounting arrangement to bolt directly to frame members and/or sprocket bolt circles.
