Go to Post If you spend the money on a new stadium, you might make a profit. If you spend the money on upgrading school lab facilities, you might inspire someone to make a vaccine for HIV. - nathanww [more]
Unread 27-10-2016, 11:26
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
adciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to all
Re: pic: Testbench with PDB backpower
Originally Posted by bobbysq View Post
Is there a way to check the current meter without having to put much in the code? I assume it'd be easy to display it in SmartDashboard or in the web config.
No code necessary. Go to the roboRIO web interface, pull up the PDB, and I think you click test. I'm going from memory here. You'll see the estimated current value for each circuit. Change the current going to that circuit and see what changes.
Originally Posted by texarkana View Post
I would not want the task of devising a system that 50,000 very smart people try to outwit.
