Re: Nonadrive Concept
I really recommend you check out the Grasshopper Hybrid drove that 624 initially showcased.
https://www.chiefdelphi.com/media/papers/2968? Also, just search for Grasshopper drives on here and you'll find several threads with a lot of great information. I'll comment on a few things, but a lot of those threads have information that would help you as well. Your speeds are high. Are those the theoretical or adjusted values? If you aren't, I'd suggest you use the JVN Design calculator to determine your actual speeds when driving. Remember that your "Weight on Driven Wheels" will not always be 100%. That can make a big difference. Also, it looks like you've got a fixed strafing wheel in the middle. With n-wheel or actuating wheel drives, you especially need to have some way to actuate your strafing wheel so you can actually get a decent amount of weight on that single wheel. I'm not a big fan of the way you've attached your actuators to the modules. It looks like there could be a lot of flex in the system, especially if the clevis rod doesn't slide along the slot as smoothly as you expect. Were that to bind mid-shift, you could end up damaging the modules if the pneumatics have enough power. I like the profile of your gearboxes. Compact gearboxes are a wonderful thing. Keep working on this design! It's a great way to test out a lot of concepts needed for building great robots. |
I think it's a great start! 80 lbs seems pretty heavy for just a drivetrain plus electronics. There definitely looks to be a lot of weight that could be cut. Is this something that your team is looking to build, or just a thought experiment?
I think the weight could be cut down quite a bit from some sort of lightning hole pattern, I just wasn't motivated to CAD model such a thing! |
I think it would be really cool if you modified this design to be built with your team's resources. Adding constraints like that make these designs much more challenging and in my opinion fun. |
Any reason for Nonadrive over Octacanum?
I chose the omni wheels over the mecanum because it would allow for faster and smoother speed in all directions. I designed this in the summer as sort of a "best possible" all around drivetrain. If we decided to build something like this, I would reconsider the Octanum option because it is easier to manufacture.
Some thoughts:
I'll echo the above comment about actuating the center wheel to get more down force. My FTC team is currently using an H-drive and having a center wheel with variable down force has proven to be very important for smooth driving. Also, it might be a good idea to reinforce the drop down wheel modules a little more. They look like they might bend easily from a side hit with the traction wheels down. Overall, this looks really good. I'm curious to see how it develops! |
Nice Job.
As others have posted, you might run into problems with your pneumatic cylinder. I would mount the cylinder with a bolt as a pivot to the back (bottom) of the cylinder. That way it can align to the wheel strut's movement path. Can anyone talk about how a bot like this turns? For example, are the turns sharp and crisp or wide and slushie? Dave |
