Go to Post Hearing about the beginnings of 842 was truly inspirational and has really stuck with me through the years. After following you guys for so long it was crazy for me to play with you. Thank you for all that you have done for FIRST in Arizona. - Saberbot [more]
Unread 11-11-2016, 10:46
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: GBX-150, CIM-mounted swerve
The main forces on the CIM are thrust loads against the face rather than shear forces, and she shear forces are limited by wheel friction.
The thrust load isn't the concern, especially as it's compression. However, if the CoF of the wheel on carpet is greater than one*, the shear forces are potentially greater than the thrust load. What really concerns me are shock loads.
* Except for Lunacy swerves, this seems to be the rule rather than an exception.
