Go to Post Come on, guys, it's two weeks 'til build. Personally, I'm gonna go outside for a little before I forget what my neighborhood looks like in the daylight. :) - Libby K [more]
Unread 11-11-2016, 13:51
Re: pic: GBX-150, CIM-mounted swerve
The thrust load isn't the concern, especially as it's compression. However, if the CoF of the wheel on carpet is greater than one*, the shear forces are potentially greater than the thrust load. What really concerns me are shock loads.
* Except for Lunacy swerves, this seems to be the rule rather than an exception.
That's a good point; I hadn't thought of it that way. Looking back on it, the whole clamping mechanism is a cool gimmick, but not something I actually need... I could also reduce the weight somewhat with other constructions I think.
Originally Posted by Bryce2471 View Post
Looks very cool. I'm glad to see you are still iterating on your swerve designs.
What I can't gather from this picture is how the primary bearing setup would work. Could we get a cross section view, or an explanation for that?
Thank you!
The bearing setup is definitely an oddball one. Here's a link to the 2015 Offseason folder with the CAD, if that helps:
https://workbench.grabcad.com/workbe...1Z2b-tQWAq3gUh
Essentially, a plate is screwed into the CIM and firmly attaches to the inner race of the 6711 bearing. The outer race of the bearing is pressed into the 64t turning gear and captured with the flanged buttonhead screws seen in the picture.
