Go to Post This is just one example of why you MUST NOT make engineering decisions based on assumptions. You should check/measure your parts and make appropriate design adjustments. - Stu Bloom [more]
Unread 11-11-2016, 16:00
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: pic: GBX-150, CIM-mounted swerve
Originally Posted by Aren_Hill View Post
I like the concept, as someone who has utilized the large steel sleeve of the CIM structurally before. ...
+1
That CIM sleeve is a beefcake. See linked cartoon-CAD of our 2016 winch. (We ended up using an igus bearing, not the PTFE called out in the cartoon. Metric 64mm i.d. fits nicely over the CIM sleeve paint. See picture of the innards also.)
My theory as a motor designer: if you have more than the minimum steel required for magnetic flux, the excess should perform another useful function to justify its weight, cost, claimed space, etc.
Richard Wallace
since 2003
