Go to Post we are all in the same boat. We'll adapt and deal with the challange. No need nashing teeth over the little stuff... - wilsonmw04 [more]
Unread 21-11-2016, 01:01
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Re: pic: Swerve Render
Those Silverthin bearings are pricey (albeit highly convenient)! I know teams that used them way back in the past have gotten sponsored.
I was worried about this. I requested a quote from Silverthin but have not heard back yet. I know the equivalent bearing from VXB is $81.77!
Originally Posted by Cothron Theiss View Post
Can you shed some light on the wheel itself? Also, any chance for the full CAD?
The wheel is to be made from ABS (either on a printer or lathe) and the tread is polyurethane tubing from sun-ray that would be pressed on and bonded with a silicone adhesive like shoe goo. The basic layout and shape of the wheel should be visible in the cross section view.
Here is a link to the CAD. If you need STEP files let me know, and I can put that up too.
Originally Posted by mman1506 View Post
Retention Compound (also made by Loctite) should work well. It can fill much larger gaps than threadlock.
I like this idea, but I'm not sure how removable it would be.
FLL Team Future imagineers
FRC Team Mean Machine
Unread 21-11-2016, 03:22
Is there a STEP format file in the folder? I can't seem to find one.
Unread 21-11-2016, 03:41
Cothron Theiss's Avatar
Huh. That's interesting. So if/when the tread wears out, do you plan on just switching out the entire module or just the wheel?
Unread 21-11-2016, 13:23
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
There was not, but I just added one! Here is the link directly to the step file.
Yes. Or we could swap out the lower caster part, which ever is easiest. (I'm guessing just swapping out the wheel will be fastest because it only requires one bolt.) Then the old wheel can get new tread, so it can be used again later.
Unread 21-11-2016, 13:50
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Are you concerned about thrust loads generated from the bevel gears at all? I can't tell what bearings you're using on your drive shaft. Especially with the draft shaft being a nut/bolt combo, it seems like those thrust loads could slowly loosen the nut and creating play in the drive shaft.
Unread 21-11-2016, 14:22
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Do you mean the wheel shaft or the vertical shaft?
If you mean the vertical drive shaft, I am not worried about thrust loads because it is supported by 0.375" ID 0.875" OD flanged bearing, and I think it will be more than strong enough.
If you mean the wheel shaft, I am not worried about thrust loads from the bevel gears, because I am much more worried about the thrust loads from driving forces on the wheel.
Also none of the shafts are a nut/bolt combo. the vertical shaft is a solid aluminum live axle, the wheel shaft is a hollow steel dead axle with a bolt through the middle of it.
Unread 21-11-2016, 14:41
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Heat and some force should get it off without too much issue. CIMs are relatively cheap and reliable anyway.
2016: FRC 865 Mentor
