Go to Post Sometimes you have to eat your vegetables, do your homework, and get some sleep. Otherwise you may get sick, have bad grades, and or fall asleep during the championship. - IKE [more]
Unread 21-11-2016, 03:41
Cothron Theiss's Avatar
Re: pic: Swerve Render
Originally Posted by Bryce2471 View Post
The wheel is to be made from ABS (either on a printer or lathe) and the tread is polyurethane tubing from sun-ray that would be pressed on and bonded with a silicone adhesive like shoe goo.
Huh. That's interesting. So if/when the tread wears out, do you plan on just switching out the entire module or just the wheel?
Unread 21-11-2016, 13:23
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Is there a STEP format file in the folder? I can't seem to find one.
There was not, but I just added one! Here is the link directly to the step file.
Yes. Or we could swap out the lower caster part, which ever is easiest. (I'm guessing just swapping out the wheel will be fastest because it only requires one bolt.) Then the old wheel can get new tread, so it can be used again later.
FLL Team Future imagineers
FRC Team Mean Machine
Unread 21-11-2016, 13:50
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Are you concerned about thrust loads generated from the bevel gears at all? I can't tell what bearings you're using on your drive shaft. Especially with the draft shaft being a nut/bolt combo, it seems like those thrust loads could slowly loosen the nut and creating play in the drive shaft.
Unread 21-11-2016, 14:22
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Do you mean the wheel shaft or the vertical shaft?
If you mean the vertical drive shaft, I am not worried about thrust loads because it is supported by 0.375" ID 0.875" OD flanged bearing, and I think it will be more than strong enough.
If you mean the wheel shaft, I am not worried about thrust loads from the bevel gears, because I am much more worried about the thrust loads from driving forces on the wheel.
Also none of the shafts are a nut/bolt combo. the vertical shaft is a solid aluminum live axle, the wheel shaft is a hollow steel dead axle with a bolt through the middle of it.
