Go to Post Even in the worst times, I get a reminder of just how wonderful my big FIRST family is. - 216Robochick288 [more]
Unread 21-11-2016, 13:50
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: pic: Swerve Render
Are you concerned about thrust loads generated from the bevel gears at all? I can't tell what bearings you're using on your drive shaft. Especially with the draft shaft being a nut/bolt combo, it seems like those thrust loads could slowly loosen the nut and creating play in the drive shaft.
Unread 21-11-2016, 14:22
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Do you mean the wheel shaft or the vertical shaft?
If you mean the vertical drive shaft, I am not worried about thrust loads because it is supported by 0.375" ID 0.875" OD flanged bearing, and I think it will be more than strong enough.
If you mean the wheel shaft, I am not worried about thrust loads from the bevel gears, because I am much more worried about the thrust loads from driving forces on the wheel.
Also none of the shafts are a nut/bolt combo. the vertical shaft is a solid aluminum live axle, the wheel shaft is a hollow steel dead axle with a bolt through the middle of it.
FLL Team Future imagineers
FRC Team Mean Machine
