Go to Post 'We're back to square one! and while we're at it, let's redesign square one.' - Bethie42 [more]
Unread 21-11-2016, 16:42
Re: pic: Swerve Render
It looks like you're missing a way to hold the CIM pinion on the shaft short of welding it on there, which I believe you can only do with a steel 11t pinion. Did you have another plan in mind?
This would likely be a custom part, but you can definitely do press-fit CIM pinions. I prefer press fit to keyed pinions personally, whenever possible.
Otherwise, Loctite or something would probably hold on. I wonder if you could even put a snap ring groove into the output shaft of the motor?
Unread 21-11-2016, 18:40
I just remembered this:
http://www.andymark.com/product-p/am-0556.htm
15t 32p press-fit for a CIM shaft. If you switch to 32p on your first stage, that's doable.
Unread 21-11-2016, 18:47
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Originally Posted by mman1506 View Post
Heat and some force should get it off without too much issue. CIMs are relatively cheap and reliable anyway.
Good to know.
Yes. This is what I originally planned to use, but I could not find a good 32dp mating gear. The WCP ones only come in 20 and 40 tooth, which are not great sizes for this.
I guess I could look into modifying a SDP/SI gear, but I wanted to keep machining work down on this design.
FLL Team Future imagineers
FRC Team Mean Machine
