Go to Post wow Paul and Rich in a photograph, i thought that if that much nerd got together that a black hole would form - Mike Schroeder [more]
  #38   Spotlight this post!
Unread 28-11-2016, 13:50
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: 3 wheel omni drive concept
And here's another look at the kickstand mechanism:
These look like they need a tweak - unless there's a real perspective issue, they'll stick about half an inch outside the frame perimeter at the start of the match (presuming a 1/2" hex shaft on those wheels).
Did you plan some sort of end caps (possibly semicircular) to serve as frame perimeter behind the bumpers on the short end?
