Go to Post You know you have bad field problems if both Dean and Woodie come out to try to fix them... :) - tim_reiher [more]
  #41   Spotlight this post!
Unread 28-11-2016, 18:53
z_beeblebrox's Avatar
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
Re: pic: 3 wheel omni drive concept
Nice work; looks like it will score at least 301 points!
I'd love to see a little more about the self-righting works and how damage is avoided when the robot tips over (that's a lot of energy that has to be dissipated). How will this avoid problems with the rule about extending more than 15" beyond the frame perimeter?
A minor plywood suggestion: offset the screws in the tabs and slots so that one side of the nut is flush with the plate that it's pressed into. The change is insignificant structurally, but speeds up assembly, as a hammer can be used to install and align the nuts, rather than each having to be inserted and precisely centered with pliers.
