Go to Post We may not have any Paris Hiltons around here (though I've heard Paul Copioli is a great kisser) - AndyB [more]
  #31   Spotlight this post!
Unread 29-11-2016, 20:31
Ari423's Avatar
Ari423 Ari423 is offline
FRC #5987 (Galaxia)
Re: pic: 3 wheel omni drive concept
Looking at the pics closely (particularly the one in post 15 of this thread), it appears that the shaft mounts through the tubing, not just the plywood.
I agree that in the pic in post 15 it looks to be going through the tube, but in the latest image on the far side there is a hole in the plywood not through the tube. On the other side of the hole there is something metal with a round bore in it, which I assumed was the bearing for the self-righting arm. I could be wrong, but that would mean that the hole for the self-righting arm either isn't modeled in the far tube or isn't at the same height as the one on the near side. I'll wait for some clarification from s_forbes for a final answer.
These could easily become "U" shafts, with the other arm pivoted on the inside of the opposite "upright". If I'm picturing this correctly, each would not interfere with the action of the other. This setup would also support some idle rollers if desired to do things like the low bar in 2016 (Of course, the main drive train would need to be modified to make contact with the carpet when somewhat on its side.)
What exactly do you mean by "U shafts"? I'm not sure what you are referring to and I am having a hard time picturing how anything U shaped (or not U shaped for that matter) could connect to both arms without having to cross through the center of the robot, which I am assuming was intentionally left open to leave room for a manipulator otherwise there is no room to mount one. Also, I'm not exactly sure what problem you are trying to solve, because I only (intentionally) raised one point in that last post.
2017-present: Mentor FRC 5987
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
