Go to Post Losing is important. In some cases, more so than winning. - JackS [more]
Unread 02-12-2016, 12:11
Re: paper: 4 CIM versus 6 CIM theoretical calculations
Originally Posted by InFlight View Post
The lead acid batteries used by FIRST are about 17 Amp-Hours. They are certainly capable of discharging in excess of 300 amps for a few seconds.
The roboRIO brown out control is based on a voltage threshold of 6.3 Volts. And thus has 5.7 volts of margin with a fully charged battery.
You could reasonably model this situation as a 12 V voltage source with 0.05 Ohms of resistance to the power distribution board; and 0.3 Ohms of resistance through each of motor controls (Talon SRX) and wiring.
A CIM motor has a stated Stall current of 131 amps at 12 volts. For the instantaneous stall current, you could model the equivalent resistance as R=V/I = 12/131=0.09 Ohms
So each CIM motor circuit would have a Series Resistance of 0.09+0.3=0.39 Ohms.
Parallel resistances are totaled as 1/Rtotal = 1/R1 + 1/R2 +…+ 1/Rn
Four CIMs have a combined parallel resistance of 0.0975 Ohms.
Six CIMS have a combined parallel resistance of 0.065 Ohms
Four CIMS
The Four CIM total Resistance is 0.05+0.0975=0.1475 Ohms
Current:
I=V/R=12V/0.1475=81.4 Amps
The voltage drop at the RoboRio is
V=I*R=60 amps =0.05*81.4= 4.07 Volts
The roboRIO has 1.63 Volts of margin for a brown out.
12-6.3-4.07=1.63
Six CIMS
The Six CIM total Resistance is 0.05+0.065=0.0115 Ohms
Current:
I=V/R=12V/0.115=104.3 Amps
V=I*R=60 amps =0.05*104.3= 5.21 Volts
The roboRIO has 0.49 Volts of margin for a brown out.
12-6.3-5.21=0.49
What happens later in the match when the Battery voltage has drooped down to 10.5 Volts?
We will leave the CIM resistance unchanged, even though they are now quite hot. Same with the wiring resistances.
Four CIMS
Current:
I=V/R=10.5V/0.1475=71.2 Amps
V=I*R=60 amps =0.05*71.2= 3.5 Volts
The roboRIO has 0.7 Volts of margin for a brown out.
10.5-6.3-3.5=0.7
Six CIMS
Current:
I=V/R=10.5V/0.115=91.3 Amps
V=I*R=60 amps =0.05*91.3= 4.57 Volts
The roboRIO is-.37 Volts below the brownout voltage.
10.5-6.3-3.5=-0.37
Summary:
Standard four CIM Drives consistently maintain a 1 Volt higher brown out margin than six CIM drives. While a Six total CIM Drive can accelerate 150% faster than a Four CIM drive, it does come at considerable more risk of brownout event. Each team will have to balance drivetrain performance vs. robot reliability for the entire match.
That's some nice math you got there. I'm not sure if your model is perfect however. Are you assuming a stalled CIM? A CIM's resistance becomes less important as it speeds up, although I assume that you are doing the math for starting from a standstill.
A possible solution to this could be just basic speed ramping.
Unread 02-12-2016, 12:51
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
Every forum needs a lurking electrical engineer.
This was just at the initial state of powering the motors, with no initial velocity.
My resistance values for the wiring resistances are just reasonable guesses. The actual amperage values could be larger or smaller, but the trends with the brownout margins would be consistent.
The other note is the motors windings only get a fraction of the full stall current; because the battery and wiring system resistance can't deliver that much current.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 03-12-2016, 12:04
Also, what happens if you go from full forwards to full reverse? Theoretically, you get 2x stall current. Practically speaking, you'll start saturating magnetic fields at some point, so it gets hard to model. Stall is a good starting point.
