Go to Post You will "generously donate" your game pieces into your opponent's goal. - johnr [more]
Unread 03-12-2016, 14:02
Re: pic: Swerve 4
Interesting module you got there. I like the use of a lazy susan to take up thrust loads from the module; I don't think I've seen that on here before.
Some questions/comments for you:
1. Why the use of #6 screws to retain your dead axle? That seems pretty weak compared to using a 1/4"-20 or a #10 screw, especially because you can use unmodified Vex tube axle for the former.
2. I like how you've designed it to be easy to make without much lathe work, with hex shaft everywhere.
3. It looks like you have only a single gear reduction to the small gear of the module rotation. By my calculations, that means you can only have a maximum ratio of 42:1 to rotate the module, which is a little too low (~370rpm from an RS-550 motor). You may need to add another stage to your VP.
4. The use of 1/8" plate to support your module is very thin, thinner than any other swerve I have seen. Consider upgrading to sticking it into a 2x1 or just 3/16" plate. You're lightening very aggressively for 1/8" plate.
As a general note, keep in mind that when losing weight, it's usually better to change your overall design rather than focus on lightening patterns. Patterns get it down maybe 1/4lb to 3/8lb on a 5.5lb swerve IME, and cannot lose significant amounts of weight.
5. You free speed looks to be around 14.4fps, which is solid.
6. I like the belted first stage. If you plan to make this IRL, I would add some kind of a tensioner just in case it doesn't turn out 100%.
7. Why do you have a bearing at the top of your module? It doesn't seem to do anything.
8. Why are you riveting the lazy susan on instead of using screws? Just curious, may or may not be an issue.
9. You shouldn't rely on the lazy susan to align your bevel gears. It will help a lot if you stick 1 or 2 bearings into the large turning gear to constrain that shaft. Right now, because the large turning gear is constrained only by the lazy susan, it can easily slosh around and screw up your bevel gear alignment.
10. If you mount the S4 over your CIM via surgical tubing, how will you keep the hex adapter from sliding upwards?
Apart from that, it looks nice. Solid lower body. Good lightening on the large gear. Not too much to make from scratch. Clamps onto 1x1.
