Re: paper: 4 CIM versus 6 CIM theoretical calculations
I was just doing calculations for the resistance limiting the current again, and I got different numbers than Jim/InFlight.
I modeled it as a 0.05 ohm resistor (battery -> PDP) and then 4 or 6 parallel CIM/wiring resistors. That got me a system resistance of 0.087 ohm for a 4-CIM drive and 0.062 ohm for a 6-CIM drive, which leads to overall current draws of only 137 and 193 amps for a 4-CIM or 6-CIM drive respectively. That seems startlingly low for an entire drivetrain's maximum current. Is 0.3ohms too much to count for a motor + wires + motor controller, or have I done something wrong? Last edited by asid61 : 08-12-2016 at 22:29. |
I was using 0.39 ohms for the motor branches circuits, as I computed the CIM resistance separately. But your results are close enough, and just as valid as my assumptions. You come to the same conclusion that the actual system can't deliver the full stall torque to each motor in either the four or six CIM drives.
Once you get moving the six CIM drive will deliver 150% of the torque; and the acceleration, and time to speed will be much better. The brownout margin is much less, so there's no free lunch. |
Out of curiosity, how would a 2CIM + 2 MiniCIM drive compare? I've often wondered if this was a practical weight saving option or if the performance drop would make it not worth the trouble.
![]() Also, what are the effects of leaving the gearing on an xCIM + xMiniCIM drive identical between all motors? We've always just geared MiniCIMs the same as CIMs hoping to get a few extra RPM out of the drive. Is this practical or is there some downside I'm not seeing? |
Edit: I'm going to presume the first, as you're discussing a performance drop. I'll get back to you, but I seem to recall that it was a performance hit, but much closer to 2 CIMs than 1 CIM. Edit3: By assuming a budget of 100A on one side of the drive train, the 2 CIM can deliver 627W at 3365 rpm, the 1+1 542W at 3093 rpm, and a 0+2 can deliver 425W at 2648 rpm. The output power loss is about 14% for 1+1 and 32% for 0+2. A definite hit, but if you're looking to save weight, it's a viable way to do it without dropping all the way to 1 CIM (247W at 1287 rpm). Quote:
The closer you are to stall, the more the CIM:MiniCIM heat ratio goes down (which is bad), but not by a large amount. The ratio gets closer to 1:1 as you go nearer to free speed as well, but by the time you are running that fast the heat generated isn't too much anyway. It's possible to gear the MiniCIM such that it's always running at a higher RPM than the CIM, perhaps by using 11t and 12t pinions, but it probably isn't necessary. Maybe a team that has done CIM + MiniCIM combos can chime in here? I wonder if using higher-resistance cables to increase your resistance would be a valid strategy to help prevent brownout of 6+ CIM drivetrains. EDIT: The numbers for a 2 CIM + 2 MiniCIM drivetrain are as follows: Approximated as 3.33 CIMs 2,931 theoretical rpm 333 W/CIM 1,108w total, compared to 1,280w for a 4-CIM drive, or about 86% as efficient. Not too great of a drop if you're running a significantly lighter robot and don't need the power. Last edited by asid61 : 09-12-2016 at 14:21. |
Typically you design your drive system around 80% of free speed which is more realistic. AndyMark always used CIMS at 4455 rpms when providing gearbox performance data in Feet per Second. A CIM + Mini CIM per side would take about 125% of the time to speed, and distance traveled compared to a two CIM drive. Last edited by InFlight : 09-12-2016 at 15:10. |
#10
If you didn't have motor controllers, or (illegally) put both motors on the same controller, this would certainly be the case. Are motor controllers designed to handle the reverse bias? - Oh, right. If you decide to change from 100% speed to 50% speed in a short period of time, you'll create the same situation, so they have to be designed that way. Never mind.
#13
Electrical Power and Mechanical Power are not the same.
The Electrical Power into the a DC Motor is Volts x Amps (Watts) The Mechanical Power Out is: Power Out = Torque*(0.112985) * Speed * (2*pi/60) in Watts Note: 1 lb-in = 0.112985 Nm, and radian/sec 2*pi/60 = rpm The Motor Efficiency is η=(Power Out) /( Power in) At near free speed, the torque and Mechanical Power approach zero. |
#14
For any of the DC motors used in First Robotics, we can also use the following equations to determine their performance:
Current (Amps) = Torque Load * ((Stall Current- Free Current)/Stall Torque) + Free Current Torque Load = (Current-Free Current) * Stall Torque/(Stall Current-Free Current) Speed = Free Speed - (Free Speed / Stall Torque) * Torque Load Last edited by InFlight : 09-12-2016 at 18:51. |
