Go to Post The scent of a smoking Globe motor is familiar to many. - Alan Anderson [more]
Unread 09-12-2016, 14:29
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: paper: 4 CIM versus 6 CIM theoretical calculations
Originally Posted by cbale2000 View Post
I'm aware that mechanically it's not critical, I was just curious as to how it affects the efficiency of the overall system. Presumably the MiniCIMs would be working harder since they would be trying to pull the other motors to a higher RPM, but I'm not sure if this would make enough of a difference in motor current to really matter.
I came up with a peak efficiency of an all-CIM drivetrain as 65%, an all-min-CIM as 57%, and a 1+1 as 61%, so no, not unless I'm missing something. The only possible issue I can think of is that when the speed is greater than the free speed of the CIM, it will be generating current rather than consuming it - I'm not sure what effect that would have on the motor controller.
Unread 09-12-2016, 14:59
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
Motors at or near free speed provide no useful torque. In a real world drive train you have torque losses such as gearbox losses, bearing drag, and chain or belt drive system losses. Thus it's really not possible, particurily in a FRC limited space to accelerate anywhere near to free speed.
Typically you design your drive system around 80% of free speed which is more realistic. AndyMark always used CIMS at 4455 rpms when providing gearbox performance data in Feet per Second.
A CIM + Mini CIM per side would take about 125% of the time to speed, and distance traveled compared to a two CIM drive.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 09-12-2016, 15:17
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
I agree that there would not be a problem while driving the robot, but there might be an issue when on blocks. I figure (using Vex's numbers and a bit of linear extrapolation) that putting a CIM and mini-CIM nose to nose at 12V would reach a free speed of 5507 rpm, at which point the mini-CIM would be drawing 7.9A, 46W of mechanical power would be transferred, and the CIM would be generating 1.6A. The CIM would switch from consuming to generating current at about 5442 rpm, so probably even a gearbox on blocks would provide enough drag. Of course, both the CIM and mini CIM free speeds have a +/- 10% variation, so if you put a fast mini and a slow CIM together, you might have some issues when running the motors with the robot on blocks.
Unread 09-12-2016, 15:23
This wouldn't cause any issues, you'd just be pumping some current back to the DC bus and everything would be fine.
Unread 09-12-2016, 18:59
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
If you didn't have motor controllers, or (illegally) put both motors on the same controller, this would certainly be the case. Are motor controllers designed to handle the reverse bias? - Oh, right. If you decide to change from 100% speed to 50% speed in a short period of time, you'll create the same situation, so they have to be designed that way. Never mind.
Unread 09-12-2016, 17:44
InFlight's Avatar
Electrical Power and Mechanical Power are not the same.
The Electrical Power into the a DC Motor is Volts x Amps (Watts)
The Mechanical Power Out is:
Power Out = Torque*(0.112985) * Speed * (2*pi/60) in Watts
Note: 1 lb-in = 0.112985 Nm, and radian/sec 2*pi/60 = rpm
The Motor Efficiency is
η=(Power Out) /( Power in)
At near free speed, the torque and Mechanical Power approach zero.
Unread 09-12-2016, 18:18
InFlight's Avatar
For any of the DC motors used in First Robotics, we can also use the following equations to determine their performance:
Current (Amps) = Torque Load * ((Stall Current- Free Current)/Stall Torque) + Free Current
Torque Load = (Current-Free Current) * Stall Torque/(Stall Current-Free Current)
Speed = Free Speed - (Free Speed / Stall Torque) * Torque Load
