Re: paper: 4 CIM versus 6 CIM theoretical calculations
Typically you design your drive system around 80% of free speed which is more realistic. AndyMark always used CIMS at 4455 rpms when providing gearbox performance data in Feet per Second. A CIM + Mini CIM per side would take about 125% of the time to speed, and distance traveled compared to a two CIM drive. Last edited by InFlight : 09-12-2016 at 15:10. |
If you didn't have motor controllers, or (illegally) put both motors on the same controller, this would certainly be the case. Are motor controllers designed to handle the reverse bias? - Oh, right. If you decide to change from 100% speed to 50% speed in a short period of time, you'll create the same situation, so they have to be designed that way. Never mind.
Electrical Power and Mechanical Power are not the same.
The Electrical Power into the a DC Motor is Volts x Amps (Watts) The Mechanical Power Out is: Power Out = Torque*(0.112985) * Speed * (2*pi/60) in Watts Note: 1 lb-in = 0.112985 Nm, and radian/sec 2*pi/60 = rpm The Motor Efficiency is η=(Power Out) /( Power in) At near free speed, the torque and Mechanical Power approach zero. |
For any of the DC motors used in First Robotics, we can also use the following equations to determine their performance:
Current (Amps) = Torque Load * ((Stall Current- Free Current)/Stall Torque) + Free Current Torque Load = (Current-Free Current) * Stall Torque/(Stall Current-Free Current) Speed = Free Speed - (Free Speed / Stall Torque) * Torque Load Last edited by InFlight : 09-12-2016 at 18:51. |
