Go to Post It means Dave Lavery isn't on the Game Design Committee this year. If he were, you probably would have found a banana instead. - Alan Anderson [more]
Unread 12-12-2016, 22:17
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
MrRiedemanJACC will become famous soon enough
Re: paper: 4 CIM versus 6 CIM theoretical calculations
Originally Posted by Richard Wallace View Post
This is not correct. Check the data, which I can vouch for. It was measured correctly by people who know their motor physics, and their FRC design.
The Mini CIM has about 2/3 the active material (armature core length, permanent magnets) compared to the CIM, and it has the same commutator.
This is why the Mini CIM performs well during prolonged heavy loading -- it does not heat up as fast internally as a CIM under the same load proportional to its size. Look at the test results provided by VexPro; after 60 seconds at peak load, the Mini CIM is still providing 200 Watts shaft output (87% of what it developed starting out with room-temperature innards), while the CIM is down to 230 Watts shaft output, only 70% of what it developed cold. Pound for pound in the heat of combat, the Mini CIM outperforms its big brother.
So I'm a dumb Mechanical Engineer and last year we had a 3 Cim per side shifting drivetrain with tracks. Obviously we could have swapped out a Cim for a Minicim to help out with shooter power and other items. (we didn't and maybe should have). But let me ask this question, How does a Cim plus 2 Minicim drivetrain compare to a 2 cim (per side) in tank drive? Assuming the rules are similar this year with open availability of other motors, would it make sense to keep the 4 cim motors for whatever gamepiece needs there are? (oh and I know I'm asking for everyone to predict the future!)
Unread 12-12-2016, 22:42
Knufire Knufire is online now
For those debating the merits of the 1:1 gearing, you might want to take a look at this thread.
https://www.chiefdelphi.com/forums/s...d.php?t=123424
To address the benefits of 4 CIM vs 6 CIM vs 4CIM+2 Mini-CIM, 234 has a paper published from a few years back with experimental data.
https://www.chiefdelphi.com/media/papers/3071
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 13-12-2016, 07:43
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
While 1C+2m would certainly have better performance than a 2 CIM drive train, that performance gain is offset by a greater weight and volume, both of motors and of the gearbox - 3 motor gearboxes usually have a higher center of gravity or more gears than a 2 motor gearbox (or both). There's also the matter of another motor controller. There are certainly cases where this would be better, but I expect they're less common than the configurations already discussed.
Unread 13-12-2016, 16:57
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
I'll second this, it certainly wouldn't be the first choice for motor configurations IMO. In general there's rarely a need to use more than 2 CIMs outside of the drive system anyways, so the number of instances you would actually need to swap out to a 1CIM+2MiniCIM should be minimal (short of maybe saving a little weight if you already have a 2CIM+1MiniCIM drive and desperately needed to loose around 1lb)
