Go to Post Our Digital Sidecar can attract metal chips from distant planets. - electroken [more]
Unread 16-12-2016, 11:34
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: 4143 differential swerve concept
Increasing the spacing between the wheels should improve steering stability. Perhaps if they were outboard of the gearboxes things would improve enough to become usable. With a bit more adjustment, this could also be used to lower the CoG of the module even farther, though with an increase in MoI around the serve axis and a need for more real estate for the module.
Originally Posted by carpedav000 View Post
If you didn't wamt steering motors on the modules, couldn't you just put a gearbox in the middle and belt-drive it to each module? Saves motors and weight.
If I understand correctly, that would be crab drive, not swerve. Crab allows you to translate anywhere, but not rotate the robot effectively.
