Go to Post Is the bottom slot just to make the whole thing look like a smiley face, or is it functional? - Chris is me [more]
Unread 16-12-2016, 12:41
Sperkowsky's Avatar
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Re: pic: FRC 2869 - 2016 Offseason bot
Originally Posted by pfreivald View Post
Had you considered putting a pneumatic spring on the intake/lift arm for stability, smoothness of operation, and reduced force necessary to lift it?
Assuming a pneumatic spring and a gas shock are the same thing, it was considered although it was a bit to late when it was. If I were to do a similar thing again I'd use a powerful normally open gas shock and a winch.
Unread 16-12-2016, 12:51
mastachyra's Avatar
mastachyra mastachyra is offline
FRC #2781 (RoboPride)
mastachyra is just really nicemastachyra is just really nicemastachyra is just really nicemastachyra is just really nice
I love how glossy the boulder is. It looks like a bowling ball that could actually destroy the castle!
2014: EtaBot - MWR/30th place/no PO
2015: ThetaBot - MWR/30th place/no PO, R2OC/Winners, IndyRAGE 5th Alliance, WMRI QF
2016: IotaBot - MWR/16th place/QF, R2OC/7th Alliance Captain/QF, Boiler Bot Battle/6th place/Finalist
Unread 16-12-2016, 13:14
pfreivald's Avatar
AKA: Patrick Freivald
Yup, same thing!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 16-12-2016, 13:36
EmileH's Avatar
EmileH EmileH is offline
it's not a water game, ok?
AKA: Emile Hamwey
FRC #1058 (PVC Pirates) & FF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
4564 used a normally opened gas shock as well as a winch for their defense manipulator/intake arm this year. One drawback was that the arm would fall when crossing defenses like the Cheval De Frise or other rough defenses as the shocks would compress. This required them to lift the arm as they crossed the CDF and others slowing down crossing times. However overall this is a better solution than a motor at the hinge point as it puts significantly less strain on the system.
In this situation a linear actuator is also an option, allowing for very precise control with little backdrive. A good example of this is 1690, as their arm had very little flex and allowed for extremely high accuracy shooting.
2016-present: High School Student, FRC 1058 PVC Pirates
2016: RiverRage 20 Champions, Battle of the Bay 3 Champions
2013-2015: Middle School Student, FRC 3467 Windham Windup
Unread 16-12-2016, 13:44
Sperkowsky's Avatar
A linear actuater would have even awesome. Unfortunately I've heard nothing but awful things about darts and with a price as high as theirs I really decided not to consider them an option.
Unread 16-12-2016, 13:57
I haven't yet heard anything bad about DARTs; do you have some discussions to link to on that? Would be good to know for the future.
As you've probably learned, rotational arm joints are sometimes tricky and require some care to do with the standard sprocket at the pivot point method of rotation. You could probably have attempted something with pneumatics, which simplifies control and is easier to make strong. Stack two pistons of different throw length on each other and now you have a four position actuator.
Unread 16-12-2016, 19:17
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
The DARTs have several eccentricities you need to work around -- they aren't "plug and play" and require a level of hardware and software understanding. If anyone is interested in details, you can PM me and I'll detail our experience. We used 2 on our arm last year.
It may change for next year, I know AM is working to make them better based on team feedback.
Also, thanks for using us as an inspiration!
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
Unread 19-12-2016, 01:58
rithinrv rithinrv is offline
Rookie Year: 2015
rithinrv is an unknown quantity at this point
What gearbox are you guys using for manipulating your arm and what is its reduction?
Unread 19-12-2016, 08:22
Sperkowsky's Avatar
The Versaplanetary has 2 10:1 stages for 100:1. It then goes into a 24t gear which goes into a 60t gear which brings the reduction to around 250:1. A chain is then driven by a 12t Sprocket which goes to a 36t sprocket making our end reduction about 750:1.
The reduction was pretty much perfect for the arm (It originally had a giant cylinder mounted to the back). The biggest issue that we cantilevered a shaft which had to deal with loads that big on a plastic gearbox.
Unread 20-12-2016, 14:46
OccamzRazor's Avatar
OccamzRazor OccamzRazor is offline
Go YETI!
AKA: Robbie
FRC #3506 (YETI)
OccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to behold
How did you guys get the motors and gearboxes in with that tubing in the way? It looks like it would take quite a while to replace anything should a motor go out or something similar.
2015 NC Regional Chairman's Award
2016 NC Guilford District Event Winner
2016 NC Guilford District Chairman's Award
2016 NC District Championship Winner
2016 NC Regional Chairman's Award
2016 NC Woodie Flowers Award Finalist - Lia Schwinghammer
Unread 20-12-2016, 15:11
Sperkowsky's Avatar
Attaching everything was very simple but repairing? Not so much. We were pretty confident that the gearboxes wouldn't break in the 1 offseason they were used at, but... They did. Ended up taking us about an hour and a half which involved taking the entire side of the chassis off, sliding out the output shaft and then carefully reassembling everything. We will definitely design stuff to be more easily repaired in the future.
