Go to Post Dave's grammar is broken. - Madison [more]
Unread 19-12-2016, 01:58
rithinrv rithinrv is offline
Rookie Year: 2015
rithinrv is an unknown quantity at this point
Re: pic: FRC 2869 - 2016 Offseason bot
What gearbox are you guys using for manipulating your arm and what is its reduction?
Unread 19-12-2016, 08:22
Sperkowsky's Avatar
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
The Versaplanetary has 2 10:1 stages for 100:1. It then goes into a 24t gear which goes into a 60t gear which brings the reduction to around 250:1. A chain is then driven by a 12t Sprocket which goes to a 36t sprocket making our end reduction about 750:1.
The reduction was pretty much perfect for the arm (It originally had a giant cylinder mounted to the back). The biggest issue that we cantilevered a shaft which had to deal with loads that big on a plastic gearbox.
Unread 20-12-2016, 14:46
OccamzRazor's Avatar
OccamzRazor OccamzRazor is offline
Go YETI!
AKA: Robbie
FRC #3506 (YETI)
OccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to behold
How did you guys get the motors and gearboxes in with that tubing in the way? It looks like it would take quite a while to replace anything should a motor go out or something similar.
2015 NC Regional Chairman's Award
2016 NC Guilford District Event Winner
2016 NC Guilford District Chairman's Award
2016 NC District Championship Winner
2016 NC Regional Chairman's Award
2016 NC Woodie Flowers Award Finalist - Lia Schwinghammer
Unread 20-12-2016, 15:11
Sperkowsky's Avatar
Attaching everything was very simple but repairing? Not so much. We were pretty confident that the gearboxes wouldn't break in the 1 offseason they were used at, but... They did. Ended up taking us about an hour and a half which involved taking the entire side of the chassis off, sliding out the output shaft and then carefully reassembling everything. We will definitely design stuff to be more easily repaired in the future.
