Go to Post God Bless the referees. - MooreteP [more]
Unread 12-30-2016, 06:45 AM
fargus111111111's Avatar
fargus111111111 fargus111111111 is offline
AKA: Tim W
FRC #0343 (Metal in Motion)
fargus111111111 is on a distinguished road
Re: pic: FRC KOP Chassis Butterfly Upgrade V1
Originally Posted by cj3958 View Post
Nice Design and modification of an existing chassis. I like the idea a lot, but I have a few comments on this implementation:
What do you use for chain/belt tensioning? as far as I can see there is none yet, which will lead to problems.
Right now it looks like the Chain you use to go from wheel to omni wheel is larger than the diameter of the wheel. The sprocket is just under the wheel, so the chain will certainly be touching the carpet. This would be bad for several reasons, the least of which is it is currently illegal to have metal touching the carpet.
Finally I think the plates you use to attach the omni wheel to the standard wheel are too weak. There is almost nothing keeping the two plates from parallelogram-ing. You have defined them so they remain parallel, but when the feel large sideways loads they will move to be a parallelogram instead of a rectangle. This wouldn't be too much of a problem except for the fact that you have chain running through these, so if it parallelograms while you move, it is a recipe for the chain to jump.
These are just some thoughts I had after looking at the grabcad for five minutes, so it is very possible I am wrong. This is just my gut reaction after looking at the design.
As far a belt tensions, the kit bot doesn't have them and if this is using the same geometry I see no reason for it to need them, the chain I'm not sure about.
If I understand the design correctly the outside plate of the kit base would still be included and that would prevent the modules from parallelograming.
Overall I like the design and the idea of being able to upgrade the kit is something I've wanted to do for a while.
I didn't break it... this time.
