Go to Post If full body suits can be made to fit properly, why do we have so many robots with saggy bumper covers? - GaryVoshol [more]
Old Yesterday, 11:36 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: Quick-Change Chassis 2
Originally Posted by Ari423 View Post
..since they are non-backdrive-able, that could be a problem when doing hard direction changes with high CoF wheels.
[With apologies to Inigo Montoya] I don'a think that word means'a what you think it means.
Non-backdriveable means that torque applied to the output shaft will encounter sufficient friction that it will not turn the motor (with no voltage applied to the motor). It does NOT mean that the system cannot be driven in reverse from the motors.
Originally Posted by Kevin Thorp View Post
We also thought about inverting the assembly, but that would make the mounting screws more difficult to reach.
While I have obviously not spent as much time with your design as you have, I don't see this at all. As I'm picturing the fasteners, this would be a matter of switching the threads from the chassis to the module, with no net difficulty in assembly, other than the requirement to hold the module up as the machine screws are being threaded. If a few alignment tools were in place, even this could be accomplished with gravity.
Old Today, 08:13 AM
Ari423's Avatar
Ari423 Ari423 is online now
FRC #5987 (Galaxia)
I'm pretty sure I know what backdriveable means. According to a thread for one of the other pictures, the gearboxes are [url=https://catalog.nordex.com/pc2743_26612]these[\url] worm gearboxes. They appear to be from the same line as the worm gearboxes we used last year, where torque on the output shaft is not transferred to the input shaft. Therefore the ones we used last year were non-backdriveable. I was cautioning that if they are the same as the ones we used, then they probably are not a good option as a drivetrain gearbox.
2017-present: Mentor FRC 5987
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
