Go to Post She must have known that if she declined the invitation to form an alliance that no one else would be allowed to pick her. (But of course, as any happy husband knows... the wife is always the #1 seed!) - dtengineering [more]
Old Today, 08:07 AM
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Re: pic: Quick-Change Motor Drive Module 1
Originally Posted by Kevin Thorp View Post
It's a Nordex GRX-A2-10 (10:1 speed reduction). Link
We've had very good luck using them to drive 6" wheels, but our sister team (342) stripped one or two out driving 12" wheels. I think they used a 20:1 ratio.
Hmm.. It looks like a few different vendors are selling the same gearbox: Nordex, SPD-SI and Torque Transmission. I wonder which one is the manufacturer?
Mentor, Team 3489, "Category 5"
Ashley Ridge H.S. & Summerville H.S.
Summerville, SC USA
Old Today, 08:34 AM
Ari423's Avatar
Ari423 Ari423 is offline
FRC #5987 (Galaxia)
How are you attaching the shaft to the gearbox? We struggled with that problem when we used them last year and ended up using a 5/8" hollow output and welding in a 5/8" OD to 1/2" ID with 1/8" key adapter so we would have a keyway. In the end this solution didn't work very well because the keyway was oversized which introduced slop into the system. We really didn't want to use the built-in roll pin because we didn't want to machine the pin holes into the shafts and were afraid of them shearing during competition and not being able to replace them. How did you solve this problem?
2017-present: Mentor FRC 5987
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
Old Today, 08:53 AM
AKA: Kevin Thorp
We inserted a 5/8" OD shaft then drilled & tapped a couple M4 holes into both the gearbox & shaft, using the existing roll pin hole as a pilot. Then installed a couple M4 screws. This seems to hold up well in competition and doesn't introduce much play.
Nordex said they could manufacture these gearboxes with 1/2" hex hollow shafts if there was enough interest from the FRC community. That would make the wheel shafts super simple!
Summerville, SC USA
Old Today, 08:53 AM
Drivencrazy's Avatar
Drivencrazy Drivencrazy is offline
AKA: Clint Ott
FRC #1011
Drivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant future
Just a word of caution: An input torque on the "output" shaft can cause a significant amount of stress in the gearbox casing leading to cracking.
For instance someone pushing you from the front or rear would create a reactionary torque in the wheel. Which would then get transmitted through the gears and into the worm gear shaft which would press against the plastic housing of the gearbox.
We sourced some of these from Torque Trans for the 2011 season and had a similar issue arise several times.
Old Today, 09:18 AM
AKA: Kevin Thorp
Yes, Team 342 had a couple Nordex gearbox failures using 12" wheels. This adds tremendous stress to the gearbox housing during pushing & abrupt stops.
Team 3489 has used them for 3 years, with no failures:
2014: Two worm gearboxes driving four wheels: two 6" Omnis and two 6" HiGrip
2015: Four worm gearboxes driving four 6" Mecanums
2016: Four worm gearboxes driving four 8" pneumatic wheels & six 4" Colsons.
Summerville, SC USA
