Go to Post As a Mississippi boy, I'm especially proud that I could read - Natchez [more]
Old Today, 08:53 AM
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Re: pic: Quick-Change Motor Drive Module 1
Originally Posted by Ari423 View Post
How are you attaching the shaft to the gearbox? We struggled with that problem when we used them last year and ended up using a 5/8" hollow output and welding in a 5/8" OD to 1/2" ID with 1/8" key adapter so we would have a keyway. In the end this solution didn't work very well because the keyway was oversized which introduced slop into the system. We really didn't want to use the built-in roll pin because we didn't want to machine the pin holes into the shafts and were afraid of them shearing during competition and not being able to replace them. How did you solve this problem?
We inserted a 5/8" OD shaft then drilled & tapped a couple M4 holes into both the gearbox & shaft, using the existing roll pin hole as a pilot. Then installed a couple M4 screws. This seems to hold up well in competition and doesn't introduce much play.
Nordex said they could manufacture these gearboxes with 1/2" hex hollow shafts if there was enough interest from the FRC community. That would make the wheel shafts super simple!
Mentor, Team 3489, "Category 5"
Ashley Ridge H.S. & Summerville H.S.
Summerville, SC USA
